Home > Message Board > Car Audio > Disc Changers > Installing a cd player
Author Thread: Installing a cd player
Username: Hoodhop10101
does sombody no were i can find the proceedure to hook up a deh-p6700mp pioneer in a 1999 mishubishi mirage de
Relevant Product Info
Username: 92_ford
i have a 92 ford festiva and a panasonic ch player but no way to intsall i need halp can any one help me
Username: Audio_russell
St.John's, Newfoundland
Im not sure of how your stock deck fits in your car but.... you will need a wiring harness that is made to fit your car model and make. then you need to fit it in with a face plate if needed. you splice the harness from your cd deck to the one that you bought to fit your car. this will make it so you can plug it into your car wires without trouble.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Disc Changers > Installing a cd player [ « Previous ] [ Next » ]
