Thread: Pioneer head unit i think |
New member Username: Meddings
Post Number: 1 Registered: Jun-06
| Posted on Thursday, June 15, 2006 - 01:01 pm: |
im not sure what is worng with my headunit or my rear speakers, my head unit is deh-p4750mp and i was driving today and all of a sudden i got alot of distortion coming out from back left speaker, and when i turn the volume down to 0 it makes a loud click noise, and it dose it now when i press any of the buttons on my head unit, loud etc. can anyone please help me i would like to know what is wrong if its the head unit or speakers, it was all working fine, but now its not, i did have a sub hooked up to a 2 channel amp but i have reaclently taken it out, would of tht caused the problem? |
Bronze Member Username: Gpz1100
Post Number: 75 Registered: Jul-05
| Posted on Sunday, June 18, 2006 - 03:24 pm: |
Try swapping speaker connections L/R to see if this follows to the other side. If not, either a speaker or a HU problem. If it does follow, then likely the HU. Check all your connections to make sure nothing is shorted or rubbing. |
