Home > Message Board > Car Audio > Head Units > Archive through June 19, 2006 > Rover car radios codes by Chassis or ...
Author Thread: Rover car radios codes by Chassis or Serial number
Username: Radiocodes
Post Number: 28
Simply click here :
http://www.radio-code.co.uk/premium_rover_radio_codes.php
Username: Illuminator
Post Number: 3145
Whoa, they don't even have a display?
Anyway, read the board policy please:
If you participate in any Forum within an eCoustics.com site,
you MUST NOT:
-advertise or sell to, or solicit others;
-use the Forum for commercial purposes of any kind;
Thanks.
Post Number: 29
I do apologise for the advertising
however Rover codes are hard to obtain in the UK now.
And Rover radios do have a display !!!
Either in the Dash or On the Radio...
Username: Beachbum
Okay, I now have the remote control working but I have no memory. I have an solid orange and a solid blue wire on the car side and a blue/white wire that are not connected anywhere, are any of these the memory?
Username: Tjmutlow
Post Number: 2346
sounds like there is a constant wire problem, put a test light on those wires and see if any of them are powered with car off....
Home > Message Board > Car Audio > Head Units > Archive through June 19, 2006 > Rover car radios codes by Chassis or ... [ « Previous ] [ Next » ]
