Thread: DEH-P6700MP help set my clock plzz!!!! |
New member Username: Sandersonma
Post Number: 1 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 11:53 pm: |
I can't remember how to set my clock in my car and i can't find my book on the head unit. Anyone know now to do it? |
New member Username: Joe504
Miami,
FL
Post Number: 3 Registered: Jun-06
| Posted on Wednesday, June 14, 2006 - 09:02 pm: |
Im not really sure, but you can try this : Press and hold the SOURCE button until the unit turns off, then press and hold the function or audio button for a couple of seconds and you will see the clock flashing, now you can set your clock using your multi-directional button. I hope it works. |
Miami,
FL
Post Number: 4 Registered: Jun-06
| Posted on Wednesday, June 14, 2006 - 09:03 pm: |
| Posted on Wednesday, June 14, 2006 - 10:49 pm: |
Thanks Joe. I'll try tonight. I've been trying forever, since the time change I guess. I just figured at least it'll be right for half the year! lol Thank you! |
Silver Member Username: Dkchillin
Vermont
Post Number: 101 Registered: Mar-05
| Posted on Wednesday, June 14, 2006 - 11:12 pm: |
Pioneer has usuer manuals on their website, but it's been down for a while now. If you still can't get it set you may want to try back there every so often to see if the site comes back up. http://www.pioneerelectronics.com/ |
