Thread: 3 Kicker comp 15's |
Anonymous |
| Posted on Monday, March 24, 2003 - 02:17 pm: |
Which one would make them sound the best? Planet Audio 2250, Hifonic Hercules, or Kicker Kx 1200.1... |
| Posted on Monday, March 24, 2003 - 05:20 pm: |
Well to be honest with you.. from the choice of amps you have there.. it would depend on personal taste... because they are all good amps.. try to listen to each one and decide which one sounds best to you... |
Anonymous |
| Posted on Monday, March 24, 2003 - 05:56 pm: |
hey Chris, which one do u think will give me the deepest and loudest bass? |
| Posted on Monday, March 24, 2003 - 06:21 pm: |
I will get back with you a little later on.. im going to do sum research on each model for you... |
