Home > Message Board > Car Audio > Disc Changers > Archive through September 05, 2006 > 2001 Altima - CD Stuck in Changer
Author Thread: 2001 Altima - CD Stuck in Changer
Username: Bdphifer
I have a 2001 Nissan Altima with a separate 6 disc CD changer. There is no brand on it, I believe it is a standard procuct. I'm not sure because I bought the car used.
I put a CD in, and it will not start. All it does is spin for 30 seconds and stop. You can't eject the CD with the button. The CD may have some marks or dust on it.
Any thoughts on how to remove it?
Username: Lexus_coop
take it apart
Home > Message Board > Car Audio > Disc Changers > Archive through September 05, 2006 > 2001 Altima - CD Stuck in Changer [ « Previous ] [ Next » ]
