Thread: Pioneer Question help needed |
New member Username: Jfletch
Post Number: 1 Registered: Jun-06
| Posted on Monday, June 12, 2006 - 04:58 pm: |
I have a Pioneer head unit that has the ipod attachment thing making the ipod an aux. hooked into the head unit and you use the controls on the head unit instead of the ipod. My question is I can't jump letters like from A to S without going all the way through. Is there anyway on the remote or the head unit that you can jump ahead in the alphabet? Thanks need help with please email if need more info or I will check here. |
New member Username: I_likes_da_bass
Bentonville,
AR
Post Number: 9 Registered: Jun-06
| Posted on Monday, June 12, 2006 - 11:42 pm: |
I don't know if it works the same using an Ipod in the aux port, but with my head unit, i just hit the function button until the list of folders comes on the screen then i can search through them until I find the track I want to play. |
Bentonville,
AR
Post Number: 10 Registered: Jun-06
| Posted on Monday, June 12, 2006 - 11:43 pm: |
