Thread: HU Contemplation |
Bronze Member Username: Bobok7787
Post Number: 20 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 07:42 pm: |
Looking for a high SQ HU that is in some way compatible with iPod. I've looked into the Alpine CDA9857 and Eclipse CD5000, dont really know any other decent HU's. Price range under $400, thanks for any input. |
Gold Member Username: Tjmutlow
Post Number: 2295 Registered: Sep-05
| Posted on Sunday, June 11, 2006 - 07:45 pm: |
i have the 9857, and the ipod speed wire hook up is great..... |
Silver Member Username: Killswitchjd
Post Number: 130 Registered: Apr-06
| Posted on Monday, June 12, 2006 - 12:16 pm: |
i have a sony model which has the aux input which plugs into any headphone port. most people dont like sony but I have had no problem. |
Silver Member Username: Johammbass
Cork,
Cork
Ireland
Post Number: 259 Registered: May-06
| Posted on Monday, June 12, 2006 - 02:57 pm: |
Alpine |
Silver Member Username: Adddisorder
West palm,
Florida
Post Number: 362 Registered: Jan-06
| Posted on Monday, June 12, 2006 - 06:28 pm: |
or look into some pioneer premiers |
Bronze Member Username: Mrsq
California
Post Number: 66 Registered: May-06
| Posted on Wednesday, June 14, 2006 - 03:26 am: |
are you talking about for under 400, geez, if your willing to spend like that then i recommend you to get primier,clarion,panasonic |
Bronze Member Username: Dkchillin
Vermont
Post Number: 100 Registered: Mar-05
| Posted on Wednesday, June 14, 2006 - 11:07 pm: |
Here's a link to a comparison chart with some decks I'd look at in that price range. There are a few on there for more that $400, but they can be had cheaper at other stores or on ebay. Keep in mind though that SQ is going to have a lot more to do with your amps and speakers than it is with your deck in that price range. comparison Chart |
Post Number: 21 Registered: Jan-06
| Posted on Thursday, June 15, 2006 - 12:33 am: |
well i have a brand new alpine amp (dont know what model) pushing a set of Diamond HEX's, and an MTX 801D pushing a 12" Diamond D6. i currently have an older Eclipse 3000 series, im leaning towards Alpine 9857, but definately open for suggestions. I sorta want to go 24 bit, but I dont know what options i have there, ill go up to $500 if it means 24 bit. |
California
Post Number: 81 Registered: May-06
| Posted on Thursday, June 15, 2006 - 01:26 pm: |
ok now. usually most hu has 24 bit built in for under 165 atleast, like what darek said that prices are lower on ebay and i assure you can get a sweet hu their, im not really a fan of kenwood but their hu with burr brown is great quality |
