Home > Message Board > Car Audio > Security Systems > Archive through August 18, 2006 > You can barely hear my alarm!!!!
Author Thread: You can barely hear my alarm!!!!
Username: Hootz
Saskatoon, Saskatchewan
Post Number: 176
I just got this thing installed a week ago. It's a compustar, and they mounted the siren up in the frong corner under the hood facing downward, so it's fairly exposed to the ground. and after driving around in the rain, I came home, and when I went to arm it, you could barely hear the chirp. if I set the thing off, it's hardly audible standing next to it. Is it just because it's wet? should I take it back to where I bought it?
Username: Camaro823
British Colu...
Post Number: 361
what kind of alarm ?
Username: Compaq19772
Liverpool
Uk
hello im looking for a wiring diagram for a kliford concept 550 can eny 1 help or tell wher i can get 1 from plezzz andy
Liverpool
Uk
hello can eny 1 help me im looking for a wiring diagram for a clifford 550 concept or wher i can get 1 from thanx andy across74@hotmail.com
Username: Outlawcam69
Chesapeake, VA
if your alarm is facing down then its not your alarm. you need to check your ground wires form good conections going to the horn. if its not a very good conection then its gonna sound weak. try grounding it somewhere else or using a bigger ground wire
Home > Message Board > Car Audio > Security Systems > Archive through August 18, 2006 > You can barely hear my alarm!!!! [ « Previous ] [ Next » ]
