Home > Message Board > Car Audio > Head Units > Archive through June 19, 2006 > Just a q????`
Author Thread: Just a q????`
Username: Darkwaters
Post Number: 14
just bought a brand new truck with sirius in it but head unit blows i have a sirius ready kd-g510 i want in its place do i need to change any of the satelite radio hardware to get siriuse on my new unit? any help would be great thanx.
Username: Dkchillin
Vermont
Post Number: 95
Is the sirius activated? The only issue will be if your sirius tuner is integrated into your stock HU, or if their's some sort of charge for transfering to new equipment. If you have an external sirius tuner then it should be a simple switch to make but it wouldn't hurt to drop sirius a line and make sure that's all you'll need to do. Here's their online form.
Username: Illuminator
Post Number: 3101
It depends on if the sirius unit is plug and play or a proprietary box made specifically for JVC.
If it's a plug and play, you can put in any deck you want as long as it has an aux-in.
If it's a proprietary unit, then you'll be limited to the few JVC units the proprietary unit will hook up to.
Either way, there isn't any charge unless you're going to buy new sirius equipment.
Post Number: 20
thanx yall been lots of help
Home > Message Board > Car Audio > Head Units > Archive through June 19, 2006 > Just a q????` [ « Previous ] [ Next » ]
