Home > Message Board > Car Audio > Head Units > Archive through June 19, 2006 > Kenwood KDC-X589
Author Thread: Kenwood KDC-X589
Username: Mac10
Hello, I purchased this HU about 4 months ago. All was working fine until today. I popped in a cd(noted, one that I have played several times) and it is now stuck in the HU. The HU is not recognizing the cd anymore. It will not eject. Any suggestions? Granted, I have not disconnected it from the power source yet. I was just looking for options.
Username: Illuminator
Post Number: 3094
The CD didn't happen to have a sticker/label on it, did it?
Username: Mac10
No, it did not. It is a retail cd. I also, disconnected the unit from the power source and then reconnected it. The cd still does not eject. It is a mini cd, but I have played it several times before with no problem. But now, the unit is responding as if there's no cd in it. When I hit the source button to switch from CD, Tuner, Standby, it only gives Tuner and Standby as options, and does not include CD.
Post Number: 3098
Ah, good, you can probably just remove the CD mech from the unit and pull the mini CD out with no damage. Most car stereo manufacturers advise against that, but I didn't know it actually worked.
Username: Mac10
As it turned out. I clicked on the eject button, the faceplate motor rotated the faceplate down, but did not eject the cd, which is what it was doing before. But this time, while the faceplate was down, I pressed and helped the eject button for a few seconds, then the cd was ejected.
Thanks for the help,
Mac
Home > Message Board > Car Audio > Head Units > Archive through June 19, 2006 > Kenwood KDC-X589 [ « Previous ] [ Next » ]
