Thread: Wiring help needed |
New member Username: Lady_t17
Post Number: 3 Registered: Jun-06
| Posted on Sunday, June 04, 2006 - 11:03 pm: |
i need the wiring diagram for a '99 ford contour SE stereo immediately!!! because my wiring harness was cut out of car |
Gold Member Username: Tjmutlow
Post Number: 2174 Registered: Sep-05
| Posted on Monday, June 05, 2006 - 06:33 am: |
1999 Ford Contour Stereo Information Constant 12V+ Orange/Black Switched 12V+ Blue/Black Ground Black/Green Illumination White/Green Dimmer n/a Antenna Right Rear Front Speakers 5" x 7" Doors Left Front (+) White/Black Left Front (-) Brown/Yellow Right Front (+) White/Red Right Front (-) Brown/Yellow Rear Speakers 5" x 7" Rear Deck Left Rear (+) White/Purple Left Rear (-) Brown/White Right Rear (+) White/Purple Right Rear (-) Brown/White
Post Number: 4 Registered: Jun-06
| Posted on Monday, June 05, 2006 - 06:38 pm: |
'99 Ford Contour SE wire colors... 2 blk/grn orng/blck grn/ white blue/ blck blue/red white white/ red white/orng purp/ white green yellow brown light blue/ blck light blue white/ red ornge/ white blck blck /blue |
Post Number: 5 Registered: Jun-06
| Posted on Monday, June 05, 2006 - 06:39 pm: |
i mean white/ grn....not grn/ white
Post Number: 2194 Registered: Sep-05
| Posted on Tuesday, June 06, 2006 - 02:05 pm: |
go to the library and look at the Chiltons manual if no one can give you what you need, or just pay to have a shop put it in, they tone generate and test light to find all the right wires. you could take a cordless battery and try and pop to find the speakers. and a test light to find power. |
