Thread: DVD- How would i go about this |
Bronze Member Username: Jth0033
Downingtown,
Pennsylvania
United States
Post Number: 36 Registered: Sep-05
| Posted on Sunday, June 04, 2006 - 12:52 am: |
alrighty i saw this dvd player on ebay, pretty cheap, which i figured i could hook up to the lcd monitors i want to install. i already have a hu and don't want to give that up, but also hook this one up. Is this possible and how would i go about that? If not should i use a modulator to relay sound to the speakers? Thanks for the help! http://cgi.ebay.com/Innovatek-386-TV-In-Dash-CAR-DVD-MP3-MP4-CD-RW-PLAYER_W0QQit emZ9735873433QQihZ008QQcategoryZ79835QQrdZ1QQcmdZViewItem |
Gold Member Username: Tjmutlow
Post Number: 2167 Registered: Sep-05
| Posted on Sunday, June 04, 2006 - 04:02 pm: |
that is a radio also, but if you want to keep yours, either you need aux in or you have to use fm mod. |
Downingtown,
Pennsylvania
United States
Post Number: 37 Registered: Sep-05
| Posted on Sunday, June 04, 2006 - 09:20 pm: |
which one is better or are they both basically the same. I have aux in on my hu but just wondering. Also what if it wasn't a radio, would i still have to do the same thing? |
Post Number: 2176 Registered: Sep-05
| Posted on Monday, June 05, 2006 - 06:38 am: |
use aux in on the radio you want to keep, not the dvd player... |
Downingtown,
Pennsylvania
United States
Post Number: 38 Registered: Sep-05
| Posted on Monday, June 05, 2006 - 08:29 am: |
yeah i gotcha, thanks for the help. |
