Thread: DEH P8mp |
New member Username: Casey_o
Post Number: 4 Registered: Dec-05
| Posted on Friday, June 02, 2006 - 10:12 pm: |
Had this in the wrong section.. i've had this headunit for a while, and today all of a sudden the face stopped opening. click open it beeps but the motor does not even try to open the face! is there a manual way to open the face to see if something inside came off? |
New member Username: Joe504
Miami,
FL
Post Number: 6 Registered: Jun-06
| Posted on Wednesday, June 14, 2006 - 09:28 pm: |
Have you try reseting the HU? if not, do it ! How? look very close and you will see a little button that you can press with a pick tool or a needle or something ... good luck. If that doesnt fix it, emmm... hope you have warranty! |
Bronze Member Username: I_likes_da_bass
Bentonville,
AR
Post Number: 21 Registered: Jun-06
| Posted on Monday, June 19, 2006 - 11:52 am: |
The ribbon cable may have broken, but to find out, you'll pretty much have to take the front of the HU apart and look at it. |
