Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > Would these crossovers work?
Author Thread: Would these crossovers work?
Username: Frshlkjuce
I have a set of focal polyglass component 6.5's that I am putting in the back of my honda civic (hole originally designed for 6x9's, and the 6x9's are no bueno). I dont have my focal crossovers anymore (when I had them uninstalled 2 years ago apparently they didnt make it out alive?). Would a set of oz vector or matrix crossovers work? I know oz makes quality stuff so I was wondering if any of those would be adequate. Your help is greatly appreciated, im debating installing all of this on my own (all the help in the world is needd!)
Username: Bobimpact
Danbury, CT
US
Post Number: 24
Try to get the Focal crossovers first, crossovers are set to work with the speaker that they came with (slopes, crossover points etc..) You've got a great set of components and theres no sense in hamstringing them by putting the wrong crossovers on them. OZ does make good stuff, but the speaker setups are different than Focals.
Post Number: 7
anybody know of anywhere that i can come across some focal x-overs?
Username: Winn
Santa Ana, California
US
Post Number: 136
Try Ebay ...
Username: Mixneffect
Orangevale, Ca.
Post Number: 972
http://www.focal.tm.fr/accueil_en.htm
Try Focal direct. They may be able to direct you to a dealer if they do not sell direct. I would even try DIY places too.
www.madisound.com
www.zalytron.com
www.solen.ca
www.partsexpress.com
www.oregondv.com
Ebay may still be your best bet though.
Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > Would these crossovers work? [ « Previous ] [ Next » ]
