Home > Message Board > Car Audio > Security Systems > Archive through August 18, 2006 > HELP! need Wiring Diagram - 2002 Dodg...
Author Thread: HELP! need Wiring Diagram - 2002 Dodge Stratus Sedan
Username: Michiganpatriot
Does anyone have a wiring diagram for a 2002 Dodge Stratus Sedan?
Username: Lordvicadin
Post Number: 26
i do
MODEL YEAR(S)
STRATUS SEDAN 2001 -2005
KEY T-HARNESS IMMOBILIZER
CHRY KEY-1 CHR-2 TRANSPONDER, REQUIRES 791 BYPASS and EXTRA IGNITION KEY (Some Vehicles)
PART COLOR LOCATION
12 VOLT CONSTANT PINK/BLACK (+) IGNITION SWITCH HARNESS
STARTER YELLOW (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 BLUE (+) IGNITION SWITCH HARNESS
IGNITION 2 GREEN/RED (+) 20 Gauge wire, 1 of 2, use the one that tests as Ignition IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 BLACK/ORANGE (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) BLACK/YELLOW (+) IN DRIVERS KICK PANEL
POWER LOCK WHITE/DARK GREEN (1-Wire Door Lock System) See NOTE *1 @ BCM, Connector C4 Pin 15, See NOTE *3
POWER UNLOCK Same wire, See DIAGRAM See DIAGRAM
DOOR TRIGGER See NOTE *2 @ BCM, See NOTE *3
DOMELIGHT SUPERVISION YELLOW (-) @ FRONT of FUSEBOX, 6-Pin Plug
TRUNK RELEASE BLACK/WHITE (5-Wire) See NOTE *5 @ BCM, Connector C4, Pin 1, See NOTE *3
SLIDING POWER DOOR N/A
HORN BLACK/RED (-) @ STEERING COLUMN HARNESS
TACH ANY wire NOT GREEN/LIGHT GREEN @ COIL PACK
WAIT TO START LIGHT N/A
BRAKE WHITE/TAN (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM LIGHT GREEN/ORANGE (+) See NOTE *4 @ BCM, Connector C4, Pin 4, See NOTE *3
ANTI-THEFT CHRYSLER'S SENTRY KEY (GRAY KEY ONLY) A TRANSPONDER SYSTEM TRANSPONDER @ IGNITION SWITCH TUMBLER
EXTRA INFORMATION
NOTE *1 this vehicle uses a 1-Wire Door Locking System, the LOCK requires a (+)Positive thru a 620 Ohm Resistor and the UNLOCK requires a (+)Positive thru a 2700 Ohm Resistor, some units will also require 2 extra relays Part #775, to connect, See DIAGRAM NOTE *2 the DRIVERS DOOR is a TAN (-) Pin 5 the PASSENGER DOOR is a TAN/RED (-) Pin 6 the DRIVERS REAR DOOR is a TAN/ORANGE (-) Pin 7 and the PASSENGER REAR DOOR is a TAN/YELLOW (-) Pin 8 when connecting to an ALARM SYSTEM use all 4 DOOR TRIGGER wires and DIODE ISOLATE. to connect, See DAIGRAM NOTE *3 the BCM (Body Control Module) is attached to FUSE/RELAY BOX located under the drivers side of the dash NOTE *4 the FACTORY DISARM wire requires a (+)Positive thru a 750 ohm Resistor and an extra relay part #775, to connect, See DIAGRAM NOTE *5 the TRUNK RELEASE System on this vehicle is a 5-Wire Type and will require an extra Relay part #775, to connect, See DIAGRAM.
or go here http://www.directwholesale.net/diagrams/printpage.asp?ModelID=19638&MakeID=16
Home > Message Board > Car Audio > Security Systems > Archive through August 18, 2006 > HELP! need Wiring Diagram - 2002 Dodg... [ « Previous ] [ Next » ]
