Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > Set up advice needed! *Cross overs......
Author Thread: Set up advice needed! *Cross overs...
Username: Mythy225719
Post Number: 73
Hi, I have a Pioneer 880 premier HU and a JL 500/1 amp... I am having
some trouble setting it up right and was wondering if you could help
me out...
I have a decent LPF on both my amp and HU... But which one should I
use? Or should I use both? When I have the Amps turned off and the
HU's to 200Hz I can hear voices coming out of my sub...
What Hz should I set the LPF to? Also which one should I use... My
decks (rear fill)are set to a HPF of 63 Hz, My doors are at 50Hz...
Thanks for your advice guys...
Username: Winn
Santa Ana, California
US
Post Number: 128
Should use the LPF on the Amp.
LPF frequency settings on the amp is depended on what's kind of the sub and enclosure that you have.
Username: Bobimpact
Danbury, CT
US
Post Number: 25
Set the LPF on the amp to no more than 125Hz at the maximum. From there play around with it between 80-125 and see what sounds best. That will also allow you to pull your interior speakers up closer to 80 with a nice gentle rolloff (12dB/Octave or less)
Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > Set up advice needed! *Cross overs...... [ « Previous ] [ Next » ]
