Home > Message Board > Car Audio > Head Units > Archive through June 19, 2006 > Can bose factory player work with sys...
Author Thread: Can bose factory player work with system?
Username: Hobbskc
Post Number: 8
Can i hook up subs and amp to a Bose factory disc player? I know I can, but would it sound as good as if I bought a new deck?
Username: Theelfkeeper
Stockbridge, GA
Post Number: 2212
i'm sure you can with a LOC, but it'll never sound as good as an aftermarket unit. i doubt there are RCA's on the back of thoes units.
Username: Tjmutlow
Post Number: 2108
bose is not a radio, it is speaker/amp system in car.....
Username: Hobbskc
Post Number: 9
It said Maxda Bose on CD player...but I don't know. Doesn't matter anymore. Was I on my way to work and it just shut down. Turned out it fried because my daughter stuck change in the CD slot the night before. Long story short...I bought a new Kenwood HU and it sounds great! :-)
Username: Bkg107
Tulsa, Oklahoma
I own an Olds Intrigue and it came with a factory Bose speaker and amp setup. Without a converter box, you won't get it to make a sound. If you have an aftermarket cd deck and the converter box hooked up correctly, It will sound almost like a competition system, once you add the subs and the amp. The most common manufacturer of these converters I guess is Scocsee (Wal-Mart House brand) and as long as you are gentle and follow directions TO THE T, it will sound great, Mine does.
Home > Message Board > Car Audio > Head Units > Archive through June 19, 2006 > Can bose factory player work with sys... [ « Previous ] [ Next » ]
