Home > Message Board > Car Audio > Multimedia Systems > Archive through July 23, 2006 > Jensen 9511
Author Thread: Jensen 9511
Username: Buford
i tried to ground the parking break wire & it didnt work... do i need that pac mod. thanks brad
Username: Jayce2000
You cant just ground it this year you actually need a switch to do it...Ground one end of the toggle switch and then the other end of the switch to the pink wire.Put in the DVD,the blue screen will come up telling you you cant watch the movie while driving.Flip the switch UP,DOWN and then back up again and you should be fine..One catch though,when you go to get out of the car,flip the switch back in the DOWN position..
Home > Message Board > Car Audio > Multimedia Systems > Archive through July 23, 2006 > Jensen 9511 [ « Previous ] [ Next » ]
