Home > Message Board > Car Audio > Head Units > Anyone Need Wiring Help!!!! > Archive through May 02, 2006
Author Thread: Archive through May 02, 2006
Username: Nypdlapd
Post Number: 206
If You need wiring help ask me!!!
Username: Barwelle
Hi, I sure need some help. I'm wiring an aftermarket stereo for an '86 toyota camry. None of the stores around here have the wiring adapter kit for this car, and I've found nothing on the internet that has the same color wires that I do. I'll give you a list of the colors and if you could help me, that'd be great. I've figured out some, but others I am not sure at all.
yellow - battery/memory
red - ignition/accessory
black - ground
white - ??
blue + yellow stripe + brown spots - ??
light green - front right spkr +
blue - front right spkr -
pink - front left spkr +
purple - front left spkr -
pink + blue stripe + red spots - ??
brown + black spots - ??
grey + red spots - ??
blue + red spots - ??
I know one of the first two is for antenna power, but I don't know which one, and there is no wire on my aftermarket radio for the fifth one!! and all the wires that have the ?? beside them, I cannot find any guide for this car that has those colors!! All help is greatly appreciated. Thanks, NYPD-LAPD!!!
Username: Nypdlapd
Post Number: 215
86 camry wiring
Right Front Speaker (+) Green Gray
Right Front Speaker (-) Blue Gray w/ Black Stripe
+12 Volt Ignition Wire Gray Red
+12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
Left Front Speaker (+) Pink White
Left Front Speaker (-) Purple White w/ Black Stripe
Ground Wire Black Black
Power Antenna Wire 1 Blue (join wires 1 & 2
Power Antenna Wire 2 together to this blue wire)
Right Rear Speaker (+) Red Purple
Right Rear Speaker (-) White Purple w/ Black Stripe
Left Rear Speaker (+) Black Green
Left Rear Speaker (-) Yellow Green w/ Black Stripe
HOPE THIS HELPS!!!
Username: Tjmutlow
Post Number: 1881
1985-86 Toyota Camry Stereo Information
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer n/a
Antenna Trigger Black/Red
Antenna Right Front
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
• Alarm Information • Cruise Information
Username: Highstone
Post Number: 111
do you know the stock wires for 06 honda accord ex v6. (i think 05 will also have the same wires. so if you have the 05 and not 06 plz post anything ..)
Username: Nypdlapd
Post Number: 220
Right Front Spkr (-) Brown w/ Black Stripe Gray w/ Black Stripe
Right Front Spkr (+) Red w/ Green Stripe Gray
Right Rear Spkr (-) Brown w/ White Stripe Purple w/ Black Stripe
Right Rear Spkr (+) Red w/ Yellow Stripe Purple
Dash Light Dimmer Wire Orange
Honda Amp Ground Wire
Left Front Spkr (-) Gray w/ Black Stripe White w/ Black Stripe
Left Front Spkr (+) Blue w/ Green Stripe White
Left Rear Spkr (-) Gray w/ White Stripe Green w/ Black Stripe
Left Rear Spkr (+) Blue w/ Yellow Stripe Green w/ Black Stripe
+12 Volt Ignition Wire Yellow w/ Red Stripe Red
+12 Volt Battery Wire White w/ Yellow Stripe Yellow
Username: Nypdlapd
Post Number: 221
SORRY
Real wires****
Ground Wire Black
Username: Highstone
Post Number: 112
where do you get these from ? if you don't mind sharing...
Username: Nypdlapd
Post Number: 222
books my dads owns a shop and i check them out and scan them in to microsoft word!!
Username: Barwelle
I'm not sure if you understand. I have these six wires that do not match up to your codes. How can I figure these out, or do you know if there are any changes to color codes that I can find out about?
Username: Nypdlapd
Post Number: 223
what wires??
Username: Nypdlapd
Post Number: 224
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer n/a
Antenna Right Front
Left Front (+) Pink
Left Rear (+) Black
Right Rear (+) Red
Username: Barwelle
sorry for the double post, but NYPD-LAPD, could you look in the book, see if it says anything about changes to the color code during that year or the odd colors I listed? this is for the 86 camry mentioned above. Thankyou.
Username: Alexwi
Sydney, NSW
Australia
Do you know the factory wires for the head unit for 99 Toyota Echo. It has 2 plugs with similar cable colour. Thank you.
Username: Nypdlapd
Post Number: 225
MARK BL YOU ASKED FOR A 1986 camry wires!!
Username: Nypdlapd
Post Number: 226
This should be the 99 echo:
Ground Wire Black
Username: Nypdlapd
Post Number: 227
Mark bl... the years from 1985-2000 carmys have the same wires for the radio...
Username: Alexwi
Sydney, NSW
Australia
There is 2 plugs on my factory 99 echo head unit.One have 4 cables and the other one have 8 cables attached. This does not include the rear speaker cables.
Both plugs have blue, pink, violet and light green cables. I do not know what the Do you know where I can find the wiring diagram or instruction. The after market cables have totally different colours to the factory head unit cables.
Username: Nypdlapd
Post Number: 231
Ground Wire Black
Username: Nypdlapd
Post Number: 246
Does it work??
Username: Nypdlapd
Post Number: 247
anyone else
Username: Lazysol
I have a 93 ford explorer sport and i cant figure out the wires. This is what i have:
Black
Green/Yellow
Yellow/Black
Blue/Red
Green/Black
Blue
And on other one is:
Lt Blue
Yellow
Brown
White/Orange
White/Red
Green
Purple
Blue something
I need ASAP Thanks Alot
Username: Nypdlapd
Post Number: 248
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
Username: Baller1
Hi there, could you tell me what the wires are for a mark 2 fiat punto. Year 2000. I dunno why but i cant figure out which is the remote turn on wire so i can put in my amp! Thanks
Username: Nypdlapd
Post Number: 249
Sorry don't have wiring diagram for any fiats!!
BUT the remote turn on wire should be BLUE!!!
Username: Grimmy311
I need a diagram for a Sony CDX-F5505X.
Username: Peterross99
Penrith, Cumbria
England
Hi i have a citroen saxo and am fitting a a new cd player which has standard colours on but the wires that are in the saxo are different do you know what they are?
Username: Salawayun
Hi, do you happpen to have the wiring for the pioneer keh 2650?
Username: Texas_bass
Houston, TX
Post Number: 333
How about a 2003 GMC Sanoma
Username: Bradgman
GAlVeStoN, Tx
Usa
Post Number: 151
Help Wiring a kenwood MP532U to the Subwoofer bc of front & rear on... topic on the head unit page
Username: Baller1
Ok just for the fiat - i've found a blue and green coloured wire. Shall i just hope its that one!? Thanks a lot
Username: Extremesound1
Coventry, RI
United states
Post Number: 131
95 chevy balzer (4dr 4wd)
Username: Nypdlapd
Post Number: 253
2003 Gmc Sonoma
Left Front Spkr (-) Light Gray
Left Front Spkr (+) Tan
Right Front Spkr (-) Light Green
Right Front Spkr (+) Dark Green
Ground Wire Black
Power Antenna Turn On Pink (if available)
+12 Volt Battery Wire Orange
Right Rear Spkr (-) Light Blue
Right Rear Spkr (+) Dark Blue
Left Rear Spkr (-) Yellow
Left Rear Spkr (+) Brown
Username: Nypdlapd
Post Number: 254
Blazer:
Constant 12V+ Orange
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Front Speakers
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers
Left Rear (+) Brown
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Username: Ninjaspank
Hey, can you help me out with the wire colors for a 2001 Ford Ranger? Thank you!
Username: Barwelle
I bought the wiring clips (harness adapter or whatever) for the camry and none of the main colors (the red-power, yellow-battery, black-ground, blue antenna wire) none of them are the same on the harness from my car and the harness that I bought.
what to do?
Username: Nypdlapd
Post Number: 255
Ford Ranger:
Right Rear Spkr (-) Blue
Right Rear Spkr (+) White w/ Blue Stripe
Right Front Spkr (-) White
Right Front Spkr (+) Blue w/ White Stripe
Left Rear Spkr (-) Red w/ Blue Stripe
Left Rear Spkr (+) White w/ Blue Stripe
Left Front Spkr (-) Blue w/ Orange Stripe
Left Front Spkr (+) Purple
Ground Wire Black
+12 Volt Ignition Wire Red
+12 Volt Battery Wire Yellow
Username: Bradgman
GAlVeStoN, Tx
Usa
Post Number: 153
honda accord 1997 please?
Username: Natthebug28
1999 suburban
well now when we do have it wired with power and sound on radio if you go above like 22 on the volume rhe power seems to go intermitent, on CD it is always intermitent whats up with that?
Username: Nypdlapd
Post Number: 260
don't know sorry natalie??
Username: Nypdlapd
Post Number: 261
1997 Accord:
Constant 12V+ Yellow/White
Switched 12V+ White/Red
Ground Black
Illumination Red/Black
Antenna Trigger Yellow/White
Antenna Left Rear
Front Speakers 5 1/4" Doors
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6 1/2" Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Username: Personal_jesus
NYPD HELP W/ 00camryLE wiring???
Username: Nypdlapd
Post Number: 276
camry
Switched 12V+ Gray
Ground Brown
Illumination Dark Green
Dimmer White/Green
Antenna Trigger n/a
Antenna Rear Window
Front Speakers 6 1/2" Doors
Left Front (+) Pink
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Black
Right Rear (+) Red
Username: Salawayun
hi Nypd-Lapd
do you have the wiring for a 94 Mitsubishi Lancer Glxi?
Username: Drivingreckless
Near tampa, Florida
United state...
Post Number: 88
Nypd-Lapd
need help wiring a 2001 nissan altima
Username: Nypdlapd
Post Number: 277
2001 altima
Constant 12V+ Pink
Switched 12V+ Blue
Ground Vehicle Chassis
Illumination Red/Green
Dimmer Red/Yellow
Antenna Trigger Green/White
Antenna Rear Window
Front Speakers 4" x 6" Doors
Left Front (+) Brown
Left Front (-) Black/Red
Right Front (-) Black/Yellow
Left Rear (+) Orange
Left Rear (-) Black/Pink
Right Rear (+) Blue
Username: Nypdlapd
Post Number: 278
lancer
Constant 12V+ Red/Black
Switched 12V+ Blue
Ground Chassis
Illumination Green/White
Dimmer Black/Yellow
Antenna Trigger White/Black
Antenna Left Rear
Left Front (+) White/Blue
Left Front (-) Black/Blue
Right Front (+) White/Red
Right Front (-) Black/Red
Left Rear (+) Yellow/Blue
Left Rear (-) Gray/Blue
Right Rear (+) Yellow/Red
Right Rear (-) Gray/Red
Username: Dbo1034
Nypd-Lapd
Please help me with the factory harness speaker wire color codes for a 2003 ford Taurus.
Username: Nypdlapd
Post Number: 290
Ground Black/Light Green
Illumination Light Blue/Red
Antenna Left Rear
Front Speakers
Left Front (+) Orange/Light Green
Left Front (-) Light Blue/White
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
Right Rear (-) Brown/Pink
Username: Dbo1034
Right on my good Man!
Username: Nypdlapd
Post Number: 291
LOL np
Username: Theceo
Post Number: 81
im helping my friend install a system and im not sure which wire to connect the antenna wire to. he has a stock hu from a 2002 ford ranger. if anyone can help me id apreciate it.
Username: Afroopuff
Post Number: 72
2006 Nissan Frontier, wires are cut and im in some serious crap HELP
Username: Nypdlapd
Post Number: 306
Radio 12v yellow
Radio Ground black
Radio Ignition green
Radio Illumination red
Factory Amp Turn-on green/white
LF Speaker +/- brown - blue
RF Speaker +/- lt. green - red
LR Speaker +/- green - black
RR Speaker +/- gray - orange
Username: Afroopuff
Post Number: 73
im checking it now, thank you SOOO MUCH yours a life saver
Username: Afroopuff
Post Number: 74
I only have :
1 Black
2 Green
2 Gray
1 Orange
1 Blue
1 Brown
1 Light Green
1 Yellow
2 Red
2006 Nissan Frontier wires are already cut, help por favor
Username: Afroopuff
Post Number: 75
i think i got it, thank you black= grey ish? haha
Username: Acalder
Richardson, TX
New to this group - looks great!
NYPD,
Great to see somebody who wants to help.
I have an 06' Accord EX (4cyl.). I want to replace the factory speakers - do you have the wire diagrams for this particular model?
Best,
Anthony C.
Username: Nypdlapd
Post Number: 307
Constant 12V+ White/Green
Ground Black
Front Speakers
Rear Speakers
Username: Andy812
1999 Ford Escort ZX2 Wire code???
Username: Pastry187
'05 F-150 6-Disc MP3 in dash.
Need to hook up remote wire, but do not know which wire the ignition/switch 12V+ is.
Thank you, Ernie.
Username: Midnightcarving
1996 ford explorer, premium sound (not JBL, but the one with the amp)
need both radio wiring harnesses!
Username: Wolffranch
Can someone please help me with a wiring diagram for an '05 Pontiac Grand Am? I have honestly looked all over, the problem I have is that my colors do not match up. Could my harness have funky wires? Is there a way to wire this by pins instead of colors? Here are the colors I have:
Black -I know what that is
Yellow - I know what that is
Red
Orange
Orange/White
Blue/White
Grey
Grey/Black
Green
Green/Black
White
White/Black
Purple
Purple/Black
Any help would be MUCH appreciated!!! Thank you!!!!
Username: Nypdlapd
Post Number: 309
Escort:
Constant 12V+ Blue/Red
Switched 12V+ Blue/Black
Ground Black
Front Speakers
Left Front (+) Purple
Left Front (-) Blue/Orange
Right Front (+) Blue/White
Right Front (-) White
Rear Speakers
Left Rear (+) White/Blue
Left Rear (-) Red/Blue
Right Rear (+) White/Green
Right Rear (-) Blue
Username: Nypdlapd
Post Number: 310
F-150::
Constant 12V+ Light Green/Pink
Switched 12V+ Black/Purple
Ground Black/Green
Front Speakers
Left Front (+) Gray/Light Blue
Left Front (-) Tan/Yellow
Rear Speakers
Left Rear (+) Orange/Light Green
Left Rear (-) Light Blue/White
Username: Nypdlapd
Post Number: 311
Explorer:::
Constant 12V+ Green/Purple
Antenna Right Front
Front Speakers
Rear Speakers
Username: Nypdlapd
Post Number: 312
05 grand am::::
Ground Black
Illumination Brown
Dimmer Gray
Antenna Trigger Pink
Front Speakers
Left Front (+) Tan
Left Front (-) Gray
Rear Speakers
Left Rear (+) Brown
Nypd-Lapd,
Thank you for your help. The only problem I have is that the colors dont match up. These are the colors that I have in my harness. Can you please help me match up these wires? Thank you!!!
Red
Orange
Orange/White
Blue/White
Grey
Grey/Black
Green
Green/Black
White
White/Black
Purple
Purple/Black
Username: Tjmutlow
Post Number: 1945
buy the aftermarket harness for that car... maybe the gm relocation harness...
Ty - This is the aftermarket harness :-(
Username: Nypdlapd
Post Number: 314
oh
the wires i gave u are the stock wire not aftermarket harness!!
sorry i unno
Username: Van_man
Boston, MA
Post Number: 91
anything for a 2000 dodge conversion van??/
Username: Lirious
Please if you would provide color code for.
1999 Mazda 626 w/ Bose
Thanks
Username: Nypdlapd
Post Number: 318
2000 dodge:
Constant 12V+ Pink
Switched 12V+ Red/White
Ground black
Antenna Right Front
Front Speakers
Left Front (+) Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Blue/Red
Rear Speakers
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Blue/Orange
Right Rear (-) Blue/White
Username: Nypdlapd
Post Number: 320
Switched 12V+ Blue/White
Front Speakers
Left Front (+) Green/Orange
Left Front (-) Green/Black
Right Front (-) Yellow/Green
Rear Speakers
Left Rear (+) Blue/Green
Left Rear (-) Blue
Right Rear (+) Blue/Black
Right Rear (-) Blue/Orange
Username: Van_man
Boston, MA
Post Number: 93
Thanks, Does it say any thing about 3.5 in the dash.. I believe they are connected with the door speakers
Username: Nypdlapd
Post Number: 327
No i am sorry:-(
Username: Van_man
Boston, MA
Post Number: 94
Thanks Again, Thats some great info base you got there. Must keep you busy helping everone...
Username: Drift247
NY
anyone have FORD BRONCO 1994 thanks
Username: Lirious
I'm thinking that in response to this:
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?tpc=4&post=682038#POST682038
you gave this:
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?tpc=4&post=682066#POST682066
Could you please double check this to verify it is for a Bose system? This looks like the regular schema. Thanks for all your help.
Username: Nypdlapd
Post Number: 328
i can't find any info on the bose system:-( sorry
Yea thats the regular!!
Username: Nypdlapd
Post Number: 329
1994 Bronco::
Ground Red or Black
Front Speakers
Left Front (-) Black/White
Right Front (-) Black/White
Rear Speakers
Left Rear (-) Pink/Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/Orange
Username: Drift247
NY
Post Number: 7
sweet thanks
Username: Nypdlapd
Post Number: 330
yea
Username: Tjmutlow
Post Number: 1951
heather, if you have the aftermarket harness, it just plugs into the factory harness and the radio wires tie into the other end of harness. Almost all aftermarket harness match up to radio colors.... not necessarily the car colors.
Username: Nypdlapd
Ontario
Post Number: 341
^^^^ Right
Username: Hpadham
I have a 1996 Nissan Altima 4dr GXE, the wiring colours for the speakers would help me greatly! Thanks Nypd-Lapd
Username: Hpadham
Username: Nypdlapd
Ontario
Post Number: 353
Constant 12V+ Pink
Switched 12V+ Blue
Ground Chassis
Illumination Red/Blue
Dimmer Red/Yellow
Front Speakers
Left Front (+) Blue/White
Left Front (-) Blue/Yellow
Right Front (+) Brown
Right Front (-) Brown/White
Rear Speakers
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
SOrry for the last reply!!!
Username: Nbarr3305
i have a 2000 dodge stratus and a clarion head unit. i have hooked up all of the wires like i am supposed to and now the radio works great off all the speakers but when i put a cd in it only runs off the tweeters not any of the other speakers... help???
Username: Nypdlapd
Ontario
Post Number: 371
I unno BUT the best thing to do would be double check wiring!!
Constant 12V+ Pink/Yellow
Illumination Orange/Brown
Dimmer Black/Light Blue
Antenna Trigger Orange/Red
Front Speakers
Left Front (+) Dark Green
Right Front (-) Dark Blue/Red
Rear Speakers
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Username: Hpadham
Thanks a bunch Nypd-Lapd
Username: Qawes
hey, do you have wiring colours for a 86 mazda 323??
Username: Tjmutlow
Post Number: 1961
1986-88 Mazda 323 Stereo Information
Ground n/a
Dimmer n/a
Antenna Driver's Pillar
Right Front (+) Blue/Red
Right Front (-) Blue/Yellow
Rear Speakers 6 1/2" Side Shelves
Left Rear (+) Blue/Red
Left Rear (-) Blue/Yellow
Right Rear (+) Blue/White
Right Rear (-) Blue/Green
Username: Motox_315
working on a 2006 mazda 6 trying to find the wiring color codes for the factory head unit. Can you help?
Username: Tjmutlow
Post Number: 1963
if your putting in an aftermarket radio, just buy the aftermarket harness for it and good luck I see no dash kits available for that cr. i can not find a current wiring diagram for that car...
Username: Childoflight
I recently purchased a used Mitsubishi Mirage DE from a used car dealer, and I came to find out a disturbing fact.
the cd deck that is in the center tower in the dash doesn't work(not so disturbing), upon further inspection, the deck was not connected at all to the wires inside!(disturbing! :-O ) someone might have taken out a good deck and put this low end aiwa deck in.
well, whatever the case, I wasn't planning on using that deck anyways :P
I need to get my pioneer deck from my old toyata tercel into my 2000 mitsubishi mirage, but whoever ripped the deck out of this mirage didn't do so with care, the wires aren't capped or taped closed, and no wiring harness at all. the wires are pretty short too. I see the normal set of 4 power type wires
red yellow black blue
and then there's a group of 8 wires that are presumeably for the speakers
(not sure of the colors right now, I can find out by going back out to my car, a lot of orange or brown colors it seemed, and there were 2 that were connected and taped together, yellow and green, i believe. what would be up with that?
so if someone could help me out with telling me the speaker colors that this 2000 mitsubishi mirage should have, that would be most helpful.
yeah, i already tried looking for a wiring harness, but no one has one in stock ot carries it all from all the stores i checked.
Username: Kkarnes897
need wiring color codes for a 93 ford econoline e250 radio?
Home > Message Board > Car Audio > Head Units > Anyone Need Wiring Help!!!! > Archive through May 02, 2006 [ « Previous ] [ Next » ]
