Thread: Directed 508D proximity Sensor |
Silver Member Username: Fandim
Reno,
Nevada
United State...
Post Number: 965 Registered: Jun-05
| Posted on Saturday, May 13, 2006 - 10:52 pm: |
Anyone know where I can find a wiriing diagram for this? |
Silver Member Username: Shepyjay
Ont
Post Number: 120 Registered: Feb-06
| Posted on Monday, May 15, 2006 - 09:27 pm: |
www.directed.com
Reno,
Nevada
United State...
Post Number: 987 Registered: Jun-05
| Posted on Tuesday, May 16, 2006 - 07:10 pm: |
Sir they dont have a wiring diagram. YAY. I check these things before I ask questions. :-P heh heh. |
New member Username: Gleds
Edmonton,
Alberta
Post Number: 1 Registered: May-06
| Posted on Tuesday, May 23, 2006 - 04:41 pm: |
red constant power, black ground, blue full trigger, green warn away. I may have warn and trigger mixed up.
Bronze Member Username: B_sharp
Post Number: 13 Registered: May-06
| Posted on Thursday, May 25, 2006 - 02:45 am: |
How well or bad would you say your 508D proximity Sensor works?? |
New member Username: Blacknblue
Tulsa,
OK
Post Number: 5 Registered: Jul-06
| Posted on Wednesday, July 19, 2006 - 12:05 am: |
So far I'm not happy with mine... Got it installed, adjusted it where I thought it was right,,,,, seemed good the first day, now almost constant alarms.... It can be setting out in the yard and nothing within 50 feet and it will warn away..... Now, I keep adjusting it lower and lower, and it still does it, but when I stick my hand in the window, it doesn't alarm.... I do however still get random alarms... Seems like if I turn it down low enough not to get false alarms, it won't hardly trigger at all... It's mounted in the center console, do they work better on the roof or is placement that critical? |
