Home > Message Board > Car Audio > Amplifiers > Archive through May 05, 2006 > West coast custom orion 2500d
Author Thread: West coast custom orion 2500d
Username: Scott_debaker
Pittsburgh, P.A.
U.S.A.
Post Number: 244
is it worth it is it a great amp?
Username: Goatin
U.S.A
Post Number: 921
Hell yeah !!!
Pittsburgh, P.A.
U.S.A.
Post Number: 248
i bought it $450 shippd waitin for it 2 come cant wait
Pittsburgh, P.A.
U.S.A.
Post Number: 249
does it have a bass knob? or no
Username: Goatin
U.S.A
Post Number: 923
I am unshure that should be in the description.
What are you going to put that beast on ?
Do you have a HO Alt ?
Pittsburgh, P.A.
U.S.A.
Post Number: 251
iam usin the amp in my dads fire bird for now but it will b goni in my car an i will b gettin a ho an the big 3 done on my car but my dads the alt. is stock an i will propley do 1200@ 4ohms an right now ill b usin 1 10 sx cant do 2 cause the space its a firebird but it should pound an when my car is done ill probley do what b did wit the 2500d on 1 15 need 2 ask him how 2 do it since i cant get my sx 15 ill get a treo an do what b did just 1 15 tho not 2
Username: Goatin
U.S.A
Post Number: 926
doesnt B have 2 sx's?
I am saveing up for a new amp and I have had my eye on that for a while even though its like 1500 more than I need.I just like it.
Let us know how it sounds. Zepco bought one too.
It will most likely be my next amp.
Do you know if it takes 4 or 0 ga wire?
Pittsburgh, P.A.
U.S.A.
Post Number: 252
i dunno the wire type but right now iam goin 2 b usin 8g but in my car 4g an b he got 2 15 treos an u can use the amp just make sure u turn the gain down so u dont blow them
Username: Goatin
U.S.A
Post Number: 929
I dont think 8 ga will work you will be poping a lot of fuses.
Maybe you should invest in new wires I have a 1200 watt amp and I use 4 ga.
that would suck to fire it up for a few minutes and pop a line fuse.
Pittsburgh, P.A.
U.S.A.
Post Number: 256
hope it does an is the wcc orion 2500d same as the regaular orion 2500d?
Username: B101
Queen City, NC
Post Number: 2736
dont even use that amp with 8ga wire or a alternator smaller than 200a! It has 2 pwr supplies!
Username: Johnnylemoine
LaPlace, Louisiana
United States
Post Number: 798
yes the WCC 2500D is the orion 2500D same amp, just has a WCC sticker on it. and no it doesnt come with a bass knob. i even got a brand new replacement amp from orion, a 1200D, and it didnt come with a bass knob.
Pittsburgh, P.A.
U.S.A.
Post Number: 257
shyt b is right it do got 2 power supplies will it b ok 2 use the 1200w @ 4ohms with the 8g?
Pittsburgh, P.A.
U.S.A.
Post Number: 258
is 4g ok or 1/0g but i have 4g inline fuse 300a
Pittsburgh, P.A.
U.S.A.
Post Number: 259
got like 130 bucks ill buy sum 1/0wire an a 0g inline fuse gezzzzz lol but the alt is stock
Pittsburgh, P.A.
U.S.A.
Post Number: 260
http://www.cardomain.com/cart
Username: Goatin
U.S.A
Post Number: 957
If I am not mistaken those power supplies are for running 2 other orion 600D or 1200D amps. and I believe 4 ga will work
Pittsburgh, P.A.
U.S.A.
Post Number: 261
orderd it $127 shippd 0gauage wire wit 2 distrution blocks an a 250a fuse an all
Username: Goatin
U.S.A
Post Number: 962
Why??
How many amps are you runing?
Pittsburgh, P.A.
U.S.A.
Post Number: 263
what u mean amps as amp amp or amp as fuse
Home > Message Board > Car Audio > Amplifiers > Archive through May 05, 2006 > West coast custom orion 2500d [ « Previous ] [ Next » ]
