Home > Message Board > Car Audio > Amplifiers > Archive through May 05, 2006 > Amp power wire question........help p...
Author Thread: Amp power wire question........help plez.....
Username: Thomas_g
NM
Post Number: 352
Does it make a difference that i have my AGU fuse about 4 inches from where i connect my amp instead of having it right by where you connect the power cable to the battery?? Thanx guyz..........
Username: L_stay_fly
Morgan city, LA
U.S.
Post Number: 34
wouldn't make a difference in sound quality....but if something would go wrong that wire from the battery on down to your fuse can get pretty hott...my homeboi hooked his like that and almost caught his car on fire...thats why i say this
Username: Thomas_g
NM
Post Number: 355
Thanx "waYLoN"........
Username: Thomas_g
NM
Post Number: 356
HA 4:20 post!
Username: Adddisorder
West palm, Florida
Post Number: 189
also if you get in a car crash and that wire gets nicked at all or even cut your going to have yourself a nice little car fire, put the fuse as close to the battery as possible like no more then a foot
Username: Thomas_g
NM
Post Number: 360
O SHIZZNIT!!!! Thanx for telling me Mat now ill put it as close as possible. About how far from battery do you think?? Thanx!!
Username: Carguy
Post Number: 5525
As close to the battery as possible, maybe 6".
Username: Thomas_g
NM
Post Number: 362
kool thanx Isaac u guyz and this site is da SHIZZNIT!!!!
Home > Message Board > Car Audio > Amplifiers > Archive through May 05, 2006 > Amp power wire question........help p... [ « Previous ] [ Next » ]
