Thread: Protection light? |
Bronze Member Username: Rollout4877
Kent,
Ohio
Post Number: 13 Registered: Apr-06
| Posted on Wednesday, May 03, 2006 - 02:07 am: |
i have two 12 inch kicker l7's with a 3000 watt amp. ive had em for a few days and i had em at like half volume and my phone rang so i turned it off and when i turned it back on the protection light was on and the subs werent workin and the amp wasnt on. i know the protection means it wont let it work for some reason but i dont know why. im thinkin maybe the amp was too hot? anyone?????? im clueless. im hoping in the morning when i go to work it works ok. thanks |
Gold Member Username: Tjmutlow
Post Number: 1967 Registered: Sep-05
| Posted on Wednesday, May 03, 2006 - 05:56 am: |
what voice coil ND WHAT AMP IS IT, ARE THEY DUAL 4 OR DUAL 2 SUBS |
Kent,
Ohio
Post Number: 14 Registered: Apr-06
| Posted on Wednesday, May 03, 2006 - 07:58 am: |
dual vc, 2 ohms and its a boss pd 3000 |
Gold Member Username: B101
Queen City,
NC
Post Number: 2720 Registered: Sep-05
| Posted on Wednesday, May 03, 2006 - 08:38 am: |
sound like u have your subs wires to a 1/2 ohm load, its a high possiblity.. rewire the sub, wire them up, and try it again! You need to wire them @ 2ohms.. http://www.the12volt.com/caraudio/woofer_configurations.asp
Kent,
Ohio
Post Number: 15 Registered: Apr-06
| Posted on Wednesday, May 03, 2006 - 11:41 pm: |
ok i seen the diagram for 2 speakers with dvc, but it shoes to wire the speakers in a series.. my box has 2 chambers, so how can i wire them in a series? |
Silver Member Username: Goatin
U.S.A
Post Number: 951 Registered: Jan-06
| Posted on Thursday, May 04, 2006 - 12:02 am: |
through the port or run both in series and hook the wire to one then run it to the other. |
Kent,
Ohio
Post Number: 16 Registered: Apr-06
| Posted on Thursday, May 04, 2006 - 07:52 am: |
its a sealed box |
Post Number: 1985 Registered: Sep-05
| Posted on Thursday, May 04, 2006 - 09:57 am: |
you have to run each speaker to 4 ohm inside the box, then use the 2 wires from box to0 amp. |
Post Number: 1986 Registered: Sep-05
| Posted on Thursday, May 04, 2006 - 10:07 am: |
All info for that amp shows nothing stable bridged. |
Kent,
Ohio
Post Number: 17 Registered: Apr-06
| Posted on Thursday, May 04, 2006 - 04:43 pm: |
"All info for that amp shows nothing stable bridged. " so ur sayin i should bridge it? i had this place do it today and i think i heard him say he wired it to 4 ohm. but wont that lose power? when it was workin fine the other day it was way louder than it is now, b4 it would rattle my rear view mirror all the way down t where i couldnt even use it. now it doesnt. |
Post Number: 1987 Registered: Sep-05
| Posted on Thursday, May 04, 2006 - 06:31 pm: |
In theory an amp brideged at 4ohms will produce the same power as a 2ohm stereo mode(on most amps)that amp shows 1/2ohm stereo stable, soo even if yopu had it 1ohm per channel, the clipping may come from not enough power supplied to amp.... |
Kent,
Ohio
Post Number: 18 Registered: Apr-06
| Posted on Thursday, May 04, 2006 - 07:50 pm: |
ok i dont think i can bridge mine since i have 2 speakers and only 2 channels on my amp right? so is there a way i can wire the speakers at 2 ohms without wiring it in a series because my box is chambered and sealed |
Post Number: 1992 Registered: Sep-05
| Posted on Thursday, May 04, 2006 - 07:54 pm: |
you can wire each sub to either 4 or 1ohm per chamber, |
