Thread: Ohms...wtf? |
Silver Member Username: Alexv305
Tavernier,
FL
Post Number: 171 Registered: Oct-05
| Posted on Tuesday, May 02, 2006 - 04:54 pm: |
Is it better to wire your subs at a higher ohm rating or lower ohm rating? Considering that the subs are still getting the rated RMS power they need. |
Bronze Member Username: Dadydolas
Post Number: 51 Registered: Mar-06
| Posted on Tuesday, May 02, 2006 - 05:14 pm: |
higher is easier on the amp |
Tavernier,
FL
Post Number: 172 Registered: Oct-05
| Posted on Tuesday, May 02, 2006 - 05:22 pm: |
it is? |
Silver Member Username: Mystre
Pemberville,
Ohio
Post Number: 120 Registered: Sep-05
| Posted on Tuesday, May 02, 2006 - 05:26 pm: |
Depends on the amp. What's ur setup? |
