Home > Message Board > Car Audio > Amplifiers > Archive through May 05, 2006 > Recommended for Alpine SWR 1242D TypeR
Author Thread: Recommended for Alpine SWR 1242D TypeR
Username: Cbtizzy
Fairfax, VA
Post Number: 13
What is the best amp for Alpines Type R sub the SWR-1242D 12" sub. I've been planning on getting the MRD605 Digital amp. What do you guys suggest?
Username: Ctmike
Ct.
Post Number: 360
just get an amp that'll give at least 600wrms to the sub and you'll be happy.
the 605 amp should work fine as long as your only using it to power 1 sub.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 563
MB quart raa 1000. rovin's setup
Username: Cbtizzy
Fairfax, VA
Post Number: 14
that's what I though, yeah I'm gonna stick with the 605. Thanks a lot does any one know where you can get an amp link? KCE-511M
Username: Cbtizzy
Fairfax, VA
Post Number: 15
that's what I though, yeah I'm gonna stick with the 605. Thanks a lot does any one know where you can get an amp link? KCE-511M its a pioneer unit it'll go from the 605 to my head unit it makes it possible for me to do all my adjustments to my amp without having to leave the front seat.
Home > Message Board > Car Audio > Amplifiers > Archive through May 05, 2006 > Recommended for Alpine SWR 1242D TypeR [ « Previous ] [ Next » ]
