Thread: 4 channel amp question |
Silver Member Username: Johnnylemoine
LaPlace,
Louisiana
United States
Post Number: 786 Registered: Aug-04
| Posted on Monday, May 01, 2006 - 11:13 pm: |
if i have a four channel amp, can i run a 2 ohm load to one set of channels, and a 4 ohm load to the other set? i have one set of components that are single 4 ohm and the other set is single 2 ohm. there shouldnt be a porblem, right? |
Gold Member Username: Tjmutlow
Post Number: 1962 Registered: Sep-05
| Posted on Tuesday, May 02, 2006 - 06:14 am: |
as long as you do not use the 2 ohm bridged your ok. |
LaPlace,
Louisiana
United States
Post Number: 790 Registered: Aug-04
| Posted on Tuesday, May 02, 2006 - 10:00 am: |
ok man, thanks. i figured there shouldnt be a problem, but my freind said he ran his like that and it went into to protect a few times. musta been a different problem. ok thanks again ty. |
Gold Member Username: Carguy
Post Number: 5518 Registered: Nov-04
| Posted on Tuesday, May 02, 2006 - 10:46 am: |
If the amp goes into protection mode, it means it's either not 2ohm stable or the gain/level wasn't set correctly. |
LaPlace,
Louisiana
United States
Post Number: 791 Registered: Aug-04
| Posted on Tuesday, May 02, 2006 - 09:48 pm: |
ok kool, thanks isaac. im pretty good at setting gains, i just wanted to make sure before i commit to buy these XXX components. they are single 2 ohm, right? thats wut the ebay description said. 1.8 actually |
Post Number: 1968 Registered: Sep-05
| Posted on Wednesday, May 03, 2006 - 05:58 am: |
RUN THEM IN STEREO MODE, ONE SIDE PER CHANNEL |
