Thread: Thud/Pop |
Bronze Member Username: Kbenz47
Rochester,
New York
United States
Post Number: 36 Registered: Jan-06
| Posted on Monday, May 01, 2006 - 08:21 pm: |
My speakers make a thud/pop noise when change songs, turn my HU on or off, or change volume from 0-1 or 1-0. Running Infinity Reference 7541 4 chnl amp to two 6.1 infinity reference comps. I have a solid ground and have the RCA's running opposite sides of the car. The gains arent set too high, any idea what could be causing this, maybe bad RCA's? |
Bronze Member Username: L_stay_fly
Morgan city,
LA
U.S.
Post Number: 17 Registered: Apr-06
| Posted on Monday, May 01, 2006 - 08:37 pm: |
i had the same problem...by any chance do you have a pioneer HU? |
Morgan city,
LA
U.S.
Post Number: 18 Registered: Apr-06
| Posted on Monday, May 01, 2006 - 08:39 pm: |
for me i found out it was the HU all along....instead of me buyin another one...i hooked up an output adaptor 10:1 Reduction and it fixed my problem...someone also told me it adds a boost to not sure how true that was.. |
Rochester,
New York
United States
Post Number: 37 Registered: Jan-06
| Posted on Monday, May 01, 2006 - 09:10 pm: |
No, I dont have a Pioneer, unfortunatly. I have a Sony, but Im lookin to buy a new one(not sony). |
Morgan city,
LA
U.S.
Post Number: 21 Registered: Apr-06
| Posted on Monday, May 01, 2006 - 09:15 pm: |
if u still have this problem after u try a different HU...then i'd say its something wrong with the amp...mine got so bad when i would eject a cd it would make my subs pretty much wanna blow out the box and hummmm like he11..it was annoyin |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1935 Registered: Feb-05
| Posted on Monday, May 01, 2006 - 09:26 pm: |
the thud/pop is because there is no turn on delay from the HU. or the amps. one or the other needs to have a delay to eliminate the thud/pop when you turn on the car. a relay will solve the problem too. |
Rochester,
New York
United States
Post Number: 38 Registered: Jan-06
| Posted on Monday, May 01, 2006 - 11:14 pm: |
so what your saying is that, Im getting this thud/pop because the HU doesnt have a delay. So when I change the song or volume from 0-1 or 1-0 its still going to make that thud/pop until I purchase a new HU which has a delay thats built in? Anyone know of any HU's that have this built in delay to prevent this stupid problem. |
Gold Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 1009 Registered: Oct-05
| Posted on Monday, May 01, 2006 - 11:20 pm: |
or you can just get a relay i beleive. i had the same problem and just got a whole new HU and it never did it again. it tends to happen to HU that are like older than 4 or 5 years. its not just pioneer. |
Rochester,
New York
United States
Post Number: 39 Registered: Jan-06
| Posted on Tuesday, May 02, 2006 - 12:51 am: |
alright, cool. thanks for the info. I was looking to get a new HU anyways. |
