Thread: Orion or JBL |
Bronze Member Username: Mateo
Post Number: 67 Registered: Oct-05
| Posted on Monday, May 01, 2006 - 11:51 am: |
i was thinking of getting either an Orion 1200D or JBL GTO 1201.1II to push a 15" TI. anyone have any opinions. |
Gold Member Username: Carguy
Post Number: 5513 Registered: Nov-04
| Posted on Monday, May 01, 2006 - 12:37 pm: |
Get the one with best warranty and lowest price. They're both good amps. |
Silver Member Username: Ctmike
Ct.
Post Number: 347 Registered: Feb-06
i'd get the jbl, but you could probably get the orion cheaper if your on a budget. |
Silver Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 553 Registered: Dec-05
| Posted on Monday, May 01, 2006 - 03:57 pm: |
JBL |
Post Number: 68 Registered: Oct-05
| Posted on Monday, May 01, 2006 - 05:42 pm: |
ok...is it true that the JBL isnt one ohm stable...but i do know it still pushes like around 1100 wrms at two ohms so...does anyone know if it is true? thanks. |
Ct.
Post Number: 350 Registered: Feb-06
| Posted on Monday, May 01, 2006 - 05:46 pm: |
http://jbl.com/car/products/product_detail.aspx?prod=GTO1201.1%20II&cat=AMP&ser= GTS&language=ENG&country=US®ion=USA |
Post Number: 74 Registered: Oct-05
| Posted on Monday, May 01, 2006 - 06:24 pm: |
thanks |
Post Number: 78 Registered: Oct-05
| Posted on Tuesday, May 02, 2006 - 08:13 am: |
ok...im not trying to be mean but that site doesnt really anwser my quesion. thanks for the site though |
Post Number: 5516 Registered: Nov-04
| Posted on Tuesday, May 02, 2006 - 08:38 am: |
According to the ad, it does 1114w rms @ 2ohms. The trick is, you have to supply 14.4v. |
Gold Member Username: B101
Queen City,
NC
Post Number: 2706 Registered: Sep-05
| Posted on Tuesday, May 02, 2006 - 10:26 am: |
Orion will be more powerfull, and is rated @ 13.8v  |
Post Number: 81 Registered: Oct-05
| Posted on Tuesday, May 02, 2006 - 04:29 pm: |
oh ok..gotcha...thanks alot guys |
Bronze Member Username: Nissankicker
Grambling,
LA
Post Number: 92 Registered: Mar-06
| Posted on Wednesday, May 03, 2006 - 09:39 am: |
Screw all that!... Get the JBL Power Series 1200.1 * The line they discontinued * It does 1200 RMS and is stable @ 1ohm ... and with a 14.4v feed it'll get in between 1400-1600 rms Search for this " JBL BP1200.1 " |
