Thread: Need help with JVC hook up. |
New member Username: Getzenboy
Mattoon,
Illinois
Post Number: 1 Registered: May-06
| Posted on Monday, May 01, 2006 - 11:24 am: |
I'm tring to instal a new JVC CD player into my wife's 1998 Dodge Neon. I have the wiring diagram for the neon and have tried to instal 2 different JVC heads, thinking that one might have been defective. On both units, I have experianced the same issue, the stero will come on for abot 3 seconds and display "See You" and then shut off. If you disconnect power, and hook it back up, it will read the same thing and shut back off. Does anyone have any thoughts on what I am doing wrong with the unit? |
Gold Member Username: Illuminator
Post Number: 2940 Registered: Apr-05
| Posted on Monday, May 01, 2006 - 04:51 pm: |
I could have sworn my response to this got through... anyway, check the yellow battery constant and red ignition power wires to make sure both are receiving power when the car is on. |
