Thread: Running neons off your amp? Help.. |
Bronze Member Username: Tyler33
Post Number: 39 Registered: Aug-05
| Posted on Monday, May 01, 2006 - 08:55 am: |
Hey guys I have 2 10 inch neon rings for my subs, and I was wondering if I should install them or not. Would it just kill my amp, or could I do that and not be a problem? If I get anything what should I get to run the neons off of, will a capacitor help? Do you guys think the rings like pretty nice, or should I just get 1 12 inch neon and mount it on my box instead. Tell me what you think, thanks. |
Silver Member Username: Alexv305
Tavernier,
FL
Post Number: 150 Registered: Oct-05
| Posted on Monday, May 01, 2006 - 11:12 am: |
Are you asking if you can connect it to your amplifiers power source? |
Post Number: 40 Registered: Aug-05
| Posted on Monday, May 01, 2006 - 11:17 am: |
Yes, I bleieve I can do that, just making sure? Will this reck my amp, or drain my battery or anything. Will a capacitor help if I hook up neons to my amp? Or is there something else that I can get, do I even need anything or can I just run it right off of my amp? Tell me what you guys think, thanks. |
Tavernier,
FL
Post Number: 161 Registered: Oct-05
| Posted on Monday, May 01, 2006 - 11:44 am: |
As far as I can remember, a friend of mine hooked a neon to his amp and melted the wire for it. So Im not too sure, because personally, I have never done that before. Anyone else have an opinion on this? |
Gold Member Username: Carguy
Post Number: 5514 Registered: Nov-04
| Posted on Monday, May 01, 2006 - 12:41 pm: |
You need to get 12v relay from Radio Shack or any electronics store for $5. Attach the remote wire from HU to trigger the amp and the neon light. This way, the neon will only be on whenever the amp is on. |
