Home > Message Board > Car Audio > Amplifiers > Archive through May 05, 2006 > Connecting remote wire......
Author Thread: Connecting remote wire......
Username: Thomas_g
NM
Post Number: 290
Where on my HU do i connect my remote wire too?? Thanx.
Username: Theelfkeeper
Stockbridge, GA
Post Number: 1926
if its aftermarket, there should be a blue wire from the back. make sure you don't mix up the REM output wire with the antenna wire, or your amps will only turn on when you turn on the radio, lol.
for a stock unit. you'll need to hook a wire in the fuse box and put a switch on it so you can turn the amps on and off via switch. there is no REM wire on a stock unit.
Username: Thomas_g
NM
Post Number: 316
kool brandon u da man.
Stockbridge, GA
Post Number: 1955
no problem
Username: Silverado_94
Hudson bay, Saskatchewan
Post Number: 14
or you can just find a spot that has power with the key on only and hook to there. itd be easier than the switch cause u might forget and leave the amp on.use a test light to find which one to use.
Username: Thomas_g
NM
Post Number: 367
yup yup thanx everyone.....
Home > Message Board > Car Audio > Amplifiers > Archive through May 05, 2006 > Connecting remote wire...... [ « Previous ] [ Next » ]
