Home > Message Board > Car Audio > Amplifiers > Archive through May 05, 2006 > Is Orion 2500d amp a sq amp?
Author Thread: Is Orion 2500d amp a sq amp?
Username: Zepcoe
TN
Us
Post Number: 221
Username: James1115
Ct
Post Number: 5766
its a class D amp so its a sub amp. You wouldnt classify a sub amp a sq amp because of the ability to have higher unnoticed distortion. If you want to know if it will control your subs look at the damping factor, slew rate, THD, and signal to noise ratio's. www.bcae1.com
Home > Message Board > Car Audio > Amplifiers > Archive through May 05, 2006 > Is Orion 2500d amp a sq amp? [ « Previous ] [ Next » ]
