Thread: Woopsi!! Haha, I Went Too Fast |
Bronze Member Username: Afroopuff
Post Number: 76 Registered: Jan-06
| Posted on Sunday, April 30, 2006 - 03:13 pm: |
Alright so i was installing a new head unit and a tv/dvd player but i was trying to go pretty quick, and i made a mistake. I was doing it at night so it took me till the day after i finished to realize what i had done. I hooked something up wrong, so the system only works when the headlights are on. I assume it is something with the illuminate and the ignition power, but what did i do. I just tested each of those wires to see which was which, what positibilites could it be, i think i capped the ignition and hooked up the illuminate, should i cap the two togather and hook it up? is that what ur supposed to do? |
Gold Member Username: Illuminator
Post Number: 2936 Registered: Apr-05
| Posted on Sunday, April 30, 2006 - 04:15 pm: |
Don't hook up the illuminate wire at all...just use the ignition. |
Post Number: 77 Registered: Jan-06
| Posted on Sunday, April 30, 2006 - 10:17 pm: |
i dont get enough power when my lights are on then....if i just have the ignition wire hooked up i dont get enough power, whihc makes me think....is there another fuse blown? |
