Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > Capacitors for low pass crossover
Author Thread: Capacitors for low pass crossover
Username: Jdub_dub
Post Number: 50
i noticed that most of the tutorials on building crossovers show that you need to use an inductor in series with the speaker to obtain a low pass network. isnt it possible to use a capacitor in parallel with the speaker to get the same result?
i forgot how to make those bode plots and how to generate the equations for the filters. and one other thing, how does the phase shift from 1st, 2nd, and 3rd order networks? for some reason i thought that 2nd order networks flip it 180 degrees, but the first order varies with frequency. is this right?
Username: Jdub_dub
Post Number: 52
i know that the impedance of a capacitor is Zc = 1/(jwC), but i dont remember how it works with the resistance and inductance of the speaker.
Username: Jdub_dub
Post Number: 56
not a single person has any input?
Username: Lordvicadin
Post Number: 28
http://www.bcae1.com/passxovr.htm im full of answeres!!
Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > Capacitors for low pass crossover [ « Previous ] [ Next » ]
