Thread: Do i need a capaciator? no cap = bad? |
New member Username: Krnricebowl57
Post Number: 9 Registered: Apr-06
| Posted on Sunday, April 30, 2006 - 12:31 am: |
hey i was wondinerg is not having a capicator bad for your alternator. about how many watts do u need before u need a cap? right now i drive a 98 honda civic stock, and lights dim with 750 watts max and 250 watts rms. the problem is the car just turns off while im driving. even without the music on it just turns off. i was wondering this is prollie resutl of no cap ? |
Silver Member Username: Ctmike
Ct.
Post Number: 337 Registered: Feb-06
| Posted on Sunday, April 30, 2006 - 12:36 am: |
not having a cap is not bad for your alt., cap. only adds to the strain on it. i'm running about 950wrms on my stock alt. on 92 accord and i've never had my car turn off. i'd take it someplace to get it looked at. |
Gold Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 6766 Registered: Jul-05
| Posted on Sunday, April 30, 2006 - 01:17 am: |
http://wickedcases.com/caraudio/capacitors.html |
Bronze Member Username: Sgerard
Post Number: 14 Registered: Apr-06
| Posted on Sunday, April 30, 2006 - 01:19 am: |
chauncey. get on aim!!! lbox.. |
Post Number: 10 Registered: Apr-06
| Posted on Sunday, April 30, 2006 - 09:29 pm: |
hmmm i don't see you on aim. anywayz. hmm. whats the point for a cap. then? i think i should get one becuase the lights do dim.but how do i knoe how many farads to get? how many should i have 1? 2? |
Bronze Member Username: Krnricebowl57
Post Number: 12 Registered: Apr-06
| Posted on Sunday, April 30, 2006 - 09:48 pm: |
ok i dont' want a cap. i see it puts more strain on the alt. so should i get a high output alt? how many amps does stock alt put out? |
Ct.
Post Number: 344 Registered: Feb-06
| Posted on Sunday, April 30, 2006 - 10:11 pm: |
go to autozone.com and look for a replacement alt. and it'll tell you the size of your stock alt. excessive amperage is doing a group buy in may for ho alt. email them and they'll get you a price quote. http://forum.ecoustics.com/bbs/messages/4/217018.html |
Gold Member Username: Carguy
Post Number: 5510 Registered: Nov-04
| Posted on Monday, May 01, 2006 - 09:23 am: |
Andrew, you could be having a battery problem. Have it checked out. |
Post Number: 13 Registered: Apr-06
| Posted on Monday, May 01, 2006 - 02:02 pm: |
battery problem? i've never had battery problem before. i can sit there and listen to the radio or music for a long time just on battery and car will start perfectly fine. |
Post Number: 5515 Registered: Nov-04
| Posted on Monday, May 01, 2006 - 02:48 pm: |
Use a DMM and measure the battery with engine off. See if it's 12.5v or higher. Now with engine on, test it again. It should be around 13.5v - 14.2v. With music on loud, monitor the voltage. If it dips below 11v, then you will need HO alternator. |
Silver Member Username: Terry6405
Sullivan,
IN
US
Post Number: 696 Registered: Sep-05
| Posted on Tuesday, May 02, 2006 - 12:36 am: |
i would say if it gets at 12v then you need one, mabey even 12.5v |
Sullivan,
IN
US
Post Number: 697 Registered: Sep-05
i would say if it gets at 12v then you need one, mabey even 12.5v, but give it a little gas to up that |
