Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2006
  Thread Last Poster Posts Pages Last Post
Car electrical probs @.@Brandon2006-04-23  22:10 ET
Orion xtr seriesdrivingreckless2006-04-23  21:39 ET
Looking for a compact ampjuliob2006-04-23  21:14 ET
2 JL 500/1James Longo20 2006-04-23  21:05 ET
ORION OR PGdrivingreckless2006-04-23  20:41 ET
Signal to noise ratiobassman32006-04-23  19:26 ET
Better Deal/setup Audiobahn or Hifonics..Nypd-Lapd2006-04-23  18:04 ET
Testing for power outputBrandon2006-04-23  16:38 ET
Where or how?Brandon2006-04-23  16:34 ET
Amp for (2) 12" Kicker Solobaric L5sJames Longo2006-04-23  14:54 ET
Lanzar OPTI4000DOptidriven2006-04-23  13:05 ET
2 12" Kicker Comp C124?juliob2006-04-23  11:49 ET
Enough Power?juliob2006-04-23  11:38 ET
Audiobahn A2801X or Rockford Fosgate Power 1000bdjuliob2006-04-23  11:36 ET
Is a KX2500.1 amp to much power for 2 12" cvx?James Longo11 2006-04-22  23:04 ET
Lightning Audio Kills MTX?!E-Down2006-04-22  18:13 ET
Speakers Vs Subwoofersjuliob2006-04-22  18:06 ET
FVCKKKKKKKKK PROBLEMMMMMMMMMMMMmarc2006-04-22  17:32 ET
I need help with wiring ampDathan D Smith2006-04-22  17:10 ET
Amp and sub questions/\/\ike2006-04-22  13:25 ET
Newbie need to know about OHMSOptidriven12 2006-04-22  12:58 ET
Dual voice coil wiring help plzjuliob2006-04-22  12:03 ET
Possable to fix this kicker amp?ctmike2006-04-22  11:11 ET
Car audio websitesDUB C17 2006-04-23  12:29 ET
AUDIOBAHN amps?????????juliob2006-04-22  00:19 ET
Helpjuliob2006-04-22  00:17 ET
Amplifier madness 2006Chauncey Brown2006-04-21  23:23 ET
Need a ampBrandon2006-04-21  21:51 ET
Memphis 16-MCD1500Eric Riffe2006-04-21  19:10 ET
Ohm ?Eric Riffe2006-04-21  19:07 ET
WHAT SHOULD I DO!?!?!?juliob2006-04-21  18:45 ET
HELPjuliob2006-04-21  18:43 ET
Need help find the right ampjuliob2006-04-21  18:37 ET
Audiobahn Digital amps?juliob2006-04-21  18:34 ET
Looking for best amplifier to power my 15 inch kicker solo baric l...juliob2006-04-21  18:32 ET
Ma audiojuliob2006-04-21  18:24 ET
Memphis vs massiveaLeXv30517 2006-04-21  17:59 ET
Amp powerAlpineinfinity2006-04-21  17:43 ET
Still dont know difference between SQ and SPL....helpTJ2006-04-21  17:13 ET
Best way to wire 2 subs to a 1 Channel Amp?Optidriven2006-04-21  16:19 ET
Need Help!!Nypd-Lapd2006-04-21  15:08 ET
Alpine type rmercsable2006-04-21  11:46 ET
Is this normalJustin Jackson2006-04-21  10:48 ET
Need a new 4 channelTerry64052006-04-21  09:01 ET
JL W3v2 and JL 500/1Brandon2006-04-21  06:57 ET
Amp for two 10" Resonant Engeering SE line subs?B20 2006-04-21  03:37 ET
Power Acoustik any good?Optidriven10 2006-04-21  01:36 ET
Wiring RecomendationsJustin Jackson11 2006-04-21  00:53 ET
What amp is best for a 15"l7Archie Clark2006-04-20  23:55 ET
Looking for amp to power 2 12" comp vxbassman319 2006-04-20  20:17 ET
Mtx 1501d/81000d...run at 1 ohm?Josh Stotts12 2006-04-20  19:01 ET
Bad rca jackskillerzracing712006-04-20  17:37 ET
RCA cables powering AMPIsaac2006-04-20  16:21 ET
Im STILL getting as buzzin noise for the amp!nick2006-04-20  13:57 ET
What kind of amp?Brandon W11 2006-04-20  09:42 ET
Looking for Xtant 1.1i'sFishy2006-04-20  02:29 ET
Help Me Connect My SystemFranky12 2006-04-20  00:45 ET
F/S 2 jl 500/1'sgage ware20 2006-04-19  23:45 ET
WHAT SHOULD I DO!?!?!?[...Rovin...]14 2006-04-19  23:43 ET
Bad power supplymarc2006-04-19  23:07 ET
Adjusting the knobs...Kevin Benton2006-04-19  22:42 ET
Fuse necessary?Mark S2006-04-19  22:06 ET
Need Help Please Explain???bassman32006-04-19  21:46 ET
SLP ampsKyle Swokowski2006-04-19  19:33 ET
Sub problemdrivingreckless2006-04-19  17:01 ET
Amp power?Travis S2006-04-19  15:52 ET
What size amp?[...Rovin...]2006-04-19  15:05 ET
? help ?[...Rovin...]2006-04-19  14:09 ET
Would it be better to run my amp bridged ?Optidriven2006-04-19  11:53 ET
What amp do you prefer?Optidriven2006-04-19  11:47 ET
Does anyone has anything on kx1200.1mickel jorje2006-04-19  10:25 ET
For salety mutlow2006-04-19  08:01 ET
Amplifier problemsInfinity Addict2006-04-19  04:34 ET
350$ for a t10001bd rockford fosgate amp should i get?Mark S12 2006-04-19  01:45 ET
Zapco vs JLBrandon10 2006-04-19  01:26 ET
Nine.1 vs kx1200.1Brandon2006-04-19  01:23 ET
Is there a .5 ohm stable ampsPolo19 2006-04-18  22:56 ET
HELP!/\/\ike22 2006-04-18  22:46 ET
Would it be better to run my amp bridged ?Rave'n2006-04-18  22:35 ET
Amp cuts out.Chris2006-04-18  17:08 ET
What should i have it set @>?killer2006-04-18  16:00 ET
Feelings on RF mono amps?Bigbadworm2006-04-18  15:15 ET
Bridging question (RCA's)kklagge2006-04-18  15:06 ET
I think I found her[...Rovin...]2006-04-18  12:11 ET
I need an ampGarrett Kaste22 2006-04-18  09:55 ET
Amp Misconduct :/ReLOaDeD2006-04-18  08:43 ET
Type-x vs. immortalMark S2006-04-18  07:32 ET
Amp mounting locationBrandon2006-04-18  07:09 ET
Quick ?Brandon2006-04-18  07:06 ET
Whats this be too much?|\/|aTT |F2006-04-18  01:39 ET
TNT Amps?ctmike2006-04-18  00:03 ET
Owners manuelTravis S2006-04-17  23:14 ET
Amp for a type-xya2006-04-17  22:40 ET
Good amp to push....drivingreckless2006-04-17  22:12 ET
Phoenix Gold Xenon mono amps any good ?Seth Lowe15 2006-04-17  22:11 ET
Closed Closed: New threads not accepted on this page
Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2006 [ « Previous ] [ Next » ]
