Home > Message Board > Car Audio > Amplifiers > Archive through May 05, 2006 > New 06' 15inch Square kicker
Author Thread: New 06' 15inch Square kicker
Username: Rwalker004
Shorewood, Minnesota
Post Number: 19
I have one New 06' square l7 15inch kicker that is 4ohms. And then I have a new memphis mono amp that is rated at 1100rms. What is the best way of hooking this up can someone help please, I need to bang.....
Username: Young_james
Post Number: 1280
when you say it's 4ohms, do you mean it is DVC 4ohm (2ohm) or DVC 2ohm (4ohm)?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 515
2 ohm is the best option
Post Number: 21
Its 4ohmss dvc
Post Number: 22
should I have got a differant amp?
Post Number: 23
PLease somebody any body
Username: Night_mirage
Amman
Jordan
Post Number: 250
Sir
If u need help you have to give us some info
your amplifier stable @ ??
2 ohm or 1 ohm or 4 ohm
and your sub is SPL sub . loud
Post Number: 24
My amp is stable @ 1ohm mono and it is a memphis 16-mcd1000
Username: James_g
TN
Post Number: 457
What's the RMS rating on your sub?
Your amp is rated at 1,100w RMS at 1 ohm, but you can only wire that one sub down to 2 ohms. Depending on the rating for that sub, you probably need a 2 ohm DVC L7 so you can wire it at 1 ohm.
Post Number: 25
would i have to much pwer if i got one more of the same amp
Username: Mtite_dabeast
Post Number: 10
lol... Why dont u get another of both the amp and the sub (if your alternator and battery can handle 2200w of constant power), and a distrubution block... then it will be no question... your rod will definitly bang... HARD!!! Solo barics are the best subs out (so i've heard). And 1100 watts for just one sub iz rediculous. Sounds like my type of system :-)
Keep us posted.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 532
not the best, they're loud
Post Number: 26
I had the 15 custom installed in the wheel well so theres not much room for another one. I think its plenty loud for me but does anyone no how high i can turn my gain up.
when I get my camera from my girlfriend i'll show some pictures. I also have a kenwood ddx7017 with tv tuner, dvd player , ipod, and a one of kind old school nintendo with wireless controllers
Post Number: 20
SICK!
I wish i had your life... *SIGH*... ;)
Username: James_g
TN
Post Number: 458
He's not running 1100w with that 4 ohm DVC sub. More like 600w or so at 2 ohms. He has to drop it to 1 ohm to get the 1100w and that's not possible with his sub.
The gain control should be on top or on the side of the amp. It might be labeled as input sensitivity. Just remember it's not a volume control.
Username: Demon_pride
Crowder, Oklahoma
Post Number: 104
"lol... Why dont u get another of both the amp and the sub (if your alternator and battery can handle 2200w of constant power), and a distrubution block... then it will be no question... your rod will definitly bang... HARD!!! Solo barics are the best subs out (so i've heard). And 1100 watts for just one sub iz rediculous. Sounds like my type of system"
Where do you get your info? Solo Barics are shitt for SQ and MTs are louder.
Post Number: 27
ANy one heard of a bridgeing module before. There is a picture of one that came with my amp. It looks to me like thats how hooking 2 amps to the one sub would work.
Home > Message Board > Car Audio > Amplifiers > Archive through May 05, 2006 > New 06' 15inch Square kicker [ « Previous ] [ Next » ]
