Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > How to Hookup HU with 3 preouts to E...
Author Thread: How to Hookup HU with 3 preouts to EQ with 1main input
Username: Patc
Hi i have Panasonic CQ-DF601U it has 3preouts front/reat/sub and i need help installing clarion EQS746 Eq it only has main in and aux in with 6channel out front/rear/sub is thier an adaptor i can get any help will be apreciated
thanks Patc
Username: Solacedagony
New Jersey
US
Post Number: 892
Are you asking how to wire the signal path? Just go from your HU front RCAs to the main in on your EQ.
Username: Van_man
Boston, MA
Post Number: 113
Ya they are called Y connectors. Connect the front and rear in, Forget the subs. unless you are running to a sub amp connect them directly to it. Or Y those in as well and let the EQ controll the sub...
Username: Maxsq
I would not use the front because the sub is a non-fade output that will give a better signal to the eq.
Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > How to Hookup HU with 3 preouts to E... [ « Previous ] [ Next » ]
