Home > Message Board > Car Audio > Multimedia Systems > Archive through July 23, 2006 > DVD Stuck
Author Thread: DVD Stuck
Username: Homegrowncam
Watauga, TX
United States
Post Number: 268
So my trailblazer came with a factory dvd player. Well the dvd got stuck in the drive and I wanted to know if there was a way to get it out?
Username: Ironslave
Offutt AFB, Nebraska
U.S.A.
Post Number: 435
did you press the eject button?
no i'm just kidding..
i dont know if there is a way to get a CD out of stock units... did you look for a pinhole around the CD tray... fo so try putting a Paper clip there to push it out
Home > Message Board > Car Audio > Multimedia Systems > Archive through July 23, 2006 > DVD Stuck [ « Previous ] [ Next » ]
