Thread: Preout voltage on Pioneer DEH P4600MP?? |
Silver Member Username: Lewass
Boomfield Hills,
MI
Post Number: 641 Registered: Jan-06
| Posted on Thursday, April 20, 2006 - 02:45 pm: |
I am running off the rear channel, what is the preout voltage on it? |
Gold Member Username: Illuminator
Post Number: 2893 Registered: Apr-05
| Posted on Thursday, April 20, 2006 - 03:50 pm: |
2 Volts. http://www.cardomain.com/item/PIODEHP4600MP It also states 2V on the Pioneer website, but ecoustics.com doesn't let me link it properly. |
Boomfield Hills,
MI
Post Number: 642 Registered: Jan-06
| Posted on Friday, April 21, 2006 - 09:48 am: |
Ok, so if I have my amp gain set at just under 1 volt, what will happen to my bass if I set it at 2 volt? It's a Kenwood eXcelon X812D |
Post Number: 2899 Registered: Apr-05
| Posted on Friday, April 21, 2006 - 12:07 pm: |
It will turn the sensitivity on the amp down resulting in less bass. However, there will be less chance of distortion when you turn the volume up loudly. |
Boomfield Hills,
MI
Post Number: 643 Registered: Jan-06
| Posted on Friday, April 21, 2006 - 01:36 pm: |
Good call, that's what I thought too, just wanted to check, and sure enough when I changed it to 2v, it was about half as loud as before. I am going to keep it at 1v, how careful should I be with the volume control? I don't go higher than 47 out of 64. |
Boomfield Hills,
MI
Post Number: 644 Registered: Jan-06
Thanks |
Silver Member Username: Kklagge
Post Number: 226 Registered: Dec-04
| Posted on Friday, April 21, 2006 - 01:52 pm: |
You're throwing a lot of distortion in there...buy a more powerful amp and set the gains the right way. |
