Thread: Sony CDX-F5710 CD Player features explained....... |
Bronze Member Username: Killswitchjd
Post Number: 35 Registered: Apr-06
| Posted on Thursday, April 20, 2006 - 02:26 pm: |
Anyone have suggestions for what the features acually do to the sound on my sony HU? There is a DSO setting (0-3), a bBEMP (on/off), a loud (on or off), plus the hipass filters on my HU, plus the high pass filters on my amp, ect..... what will each one do to the sound (so I can make them sound how I want them to)? THanks |
Gold Member Username: Illuminator
Post Number: 2894 Registered: Apr-05
| Posted on Thursday, April 20, 2006 - 03:57 pm: |
DSO=Dynamic Soundstage Organizer, it makes lower mounted speakers sound like they're higher in the door then they really are. bBEMP? Haven't heard of that, maybe BEEP? So you can turn off the ugly beeping sound it makes everytime you press a button? Loud=boosts the highs and lows at lower volumes, but it has no effect at moderate to loud volumes (though sometimes the music will distort more easily). The highpass filters let only the high frequencies pass through. You set a crossover point where the lows will be cut off (theoretically, though it isn't like a brick wall, there's slope octave dB and all that fun stuff which means you'll still get some lows mixed in...). The highpass filters don't apply to the subwoofer pre-out. The whole reason to use a highpass filter (HPF) is so the smaller speakers won't distort as easily when the volume is turned up and can more accurately reproduce mid to high frequencies. |
Post Number: 39 Registered: Apr-06
| Posted on Thursday, April 20, 2006 - 07:58 pm: |
BBE MP is what it is, but what does it do? it boosts the volume somehow......... |
Post Number: 2897 Registered: Apr-05
| Posted on Thursday, April 20, 2006 - 08:16 pm: |
Ahh, 'Barcus Berry Enhancement', it's a great thing to have turned on. http://www.bbesound.com/technologies/BBE_MP/ |
Bronze Member Username: Mrbass
Long beach,
California
United state
Post Number: 30 Registered: Feb-06
| Posted on Saturday, April 29, 2006 - 08:54 pm: |
bbe mp process effectively adds warmth and provides a clear cd quality sound from heavily compressed matrials, thats why bbe mp is special |
