Thread: Which navigation system to use? |
New member Username: Tony007
Post Number: 1 Registered: Apr-06
| Posted on Thursday, April 20, 2006 - 05:03 am: |
Can somebody give me advise where I can find a good Navigation software for my mobile phone? |
Post Number: 2 Registered: Apr-06
| Posted on Tuesday, June 27, 2006 - 07:51 am: |
In the mean time I have found a nice navigation software for my mobile phone. It is called nav4all. This software can be easily downloaded from their website to your mobile phone. then you can use it right away. It is also free till august, so just try it yourself. then you can decide whether you like it or not. |
New member Username: Susiehe
Post Number: 9 Registered: May-09
| Posted on Friday, May 15, 2009 - 04:08 am: |
Hi,buddy, I know a website where you can buy high quality/price ratio GPS units----www.zorrogps.com. That's where I purchased my first GPS product and it works quite well. |
New member Username: Joy284
China
Post Number: 9 Registered: Oct-08
| Posted on Monday, June 01, 2009 - 12:16 am: |
Or i think you can go to visit the official website,there would provide it. |
Bronze Member Username: Susiehe
Post Number: 14 Registered: May-09
| Posted on Tuesday, August 18, 2009 - 06:22 am: |
As for GPS, I really want more functions besides navigation. For example, I want the POI warning. I mean that when I get close to the POI around me, I want my GPS software to inform me, so that I wonĄŻt miss regretfully. Luckily, my new software ZorroGPS can make it. And the POI types it provide are various, including hospital, garden and museum. |
New member Username: Limlin
Post Number: 5 Registered: Aug-09
| Posted on Monday, August 31, 2009 - 05:06 am: |
The GPS on mobile phone....What is OS of your phone? You can try the free trial ZorroGPS about one week. I'm now using that. It's OK. |
New member Username: Jianfly
Post Number: 2 Registered: Sep-09
| Posted on Thursday, September 03, 2009 - 02:31 am: |
Of course is Tomtom or Garmin. They are the most famous two GPS brands, but also very expensive. If you do not want spend too much on GPS, you can search some cheap GPS on internet and before install, make sure the GPS can run on your phone. |
