Thread: Is my head unit blown |
New member Username: Kewday101
Post Number: 1 Registered: Apr-06
| Posted on Thursday, April 20, 2006 - 04:17 am: |
ok im really worried i was wireing my head unit and the ground lead made a small spark and wouldnt turn on??????? im really worried i hope its just a fuse or something really minor. there was no smoke and i couldnt smell anything which is a good sign |
Post Number: 2 Registered: Apr-06
| Posted on Thursday, April 20, 2006 - 06:42 pm: |
Bump!!!!!!! |
Gold Member Username: Illuminator
Post Number: 2895 Registered: Apr-05
| Posted on Thursday, April 20, 2006 - 07:13 pm: |
Have you checked all of the fuses in the main fuse panel? |
Silver Member Username: Nypdlapd
Post Number: 270 Registered: Feb-06
| Posted on Thursday, April 20, 2006 - 10:51 pm: |
Check the fuse "cig lighter" because the same thing happened to me and the radio is grounded to the cig lighter!! the fuse maybe labeled horn or cig light!! |
Post Number: 3 Registered: Apr-06
| Posted on Friday, April 21, 2006 - 02:20 am: |
i found out i had only blown a fuse big relief thanks for the help |
