Thread: EQ & CROSS OVER |
Silver Member Username: Bakerj72
Regina,
Saskatchewan
Post Number: 128 Registered: Jun-05
| Posted on Wednesday, April 19, 2006 - 05:53 pm: |
what are good settings for had bass and for listening to rap i have a 9835 and a 10w7<--500/1 if you could tell me some good settings or show me a site that will teach me to put in the right settings that would be great! i personalize makes it easy but im a dumbass |
Regina,
Saskatchewan
Post Number: 129 Registered: Jun-05
| Posted on Wednesday, April 19, 2006 - 05:55 pm: |
oh its a 5 band with ajustable slope |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 889 Registered: Oct-04
| Posted on Tuesday, April 25, 2006 - 12:20 pm: |
Generally, when you decide to put in eq in your system, you want to have access to an RTA. An RTA lets you see where your response is high and low. You can then use your eq to make the response flat. |
