Home > Message Board > Car Audio > Amplifiers > Archive through April 17, 2006 > Installation
Author Thread: Installation
Username: Drivingreckless
Nuthingsville, Florida
United state...
Post Number: 60
how do u ussually remove the radio of ne car not ne in particullar....
Username: B101
Queen City, NC
Post Number: 2341
u remove the screws that holds the raido to the dash or frame of the dash...
Username: Theelfkeeper
Stockbridge, GA
Post Number: 1775
look for a Haynes or Chilton manual for the car. it'll show you how to get the dash appart and get to everything. very useful books.
it all depends on the car though. gotta remove all the trim pieces from around the radio, then get to whatever method is used to hold the radio in.
Home > Message Board > Car Audio > Amplifiers > Archive through April 17, 2006 > Installation [ « Previous ] [ Next » ]
