Thread: Memphis 16-MCD1500 |
New member Username: Troy81
Tavernier,
Fl
Us
Post Number: 2 Registered: Mar-06
| Posted on Monday, April 17, 2006 - 11:56 am: |
this amp says it is 1500rms at 2 ohms,no 1 ohm rating or i wouldnt even be asking, my subs are running at 1.5 ohms right now, i havent bought the amp yet and i was wondering if its just gonna go into protection, if not whats onna happen? thank you |
Gold Member Username: B101
Queen City,
NC
Post Number: 2339 Registered: Sep-05
| Posted on Monday, April 17, 2006 - 07:12 pm: |
its gonna play just fine @ 1.5 ohms.. Im hopin your chargin system is uptodate, and you are using atleast 4ga for your wires.. I had a mcd500 rated at 2ohms, hooked @ 1ohm for over 4mnths setup that way... so just be carefull with chargin system.. |
