Home > Message Board > Car Audio > Amplifiers > Archive through April 17, 2006 > Audiobahn A2300HCT 2CH amp
Author Thread: Audiobahn A2300HCT 2CH amp
Username: Kicker101
Alberta
Post Number: 24
hey what up, it sayd that this amp is 4800wtts but then it says its says its 2400wtts. Is this because its 2 channel. I dont get that can you explain stuff about amps and every thing and also is this model below the best audiobahn amp?
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13506
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 407
that amp is not 4800w, that might be a max power measure and you should never look at that, you should look rms, than amp is not bad at all it might be a little overrated but it still has a good performance
Username: Troy81
Tavernier, Fl
Us
gewww
dont go audiobahn, buy memphis
Username: Carguy
Post Number: 5472
I've tested the HCT model, quite good. Make sure you have HO alternator for it. It will draw lot of current, hense (HCT).
Home > Message Board > Car Audio > Amplifiers > Archive through April 17, 2006 > Audiobahn A2300HCT 2CH amp [ « Previous ] [ Next » ]
