Thread: Wiring Two Amps |
Bronze Member Username: Ecko_man2k2
Post Number: 12 Registered: Sep-05
| Posted on Sunday, April 16, 2006 - 05:47 pm: |
What the best way to wire up two amps. Im talking about...Power...Ground....Remote..yeah Thanx |
Gold Member Username: Tjmutlow
Post Number: 1911 Registered: Sep-05
| Posted on Monday, April 17, 2006 - 04:15 am: |
use a distribution block off the main power wire for the amps...and split the remote wire...ground each amp seperate... |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1765 Registered: Feb-05
| Posted on Monday, April 17, 2006 - 06:54 am: |
i'd run the ground wire from each amp to the same ground point. less likely to get unwanted noise that way. |
Bronze Member Username: Car1
Post Number: 19 Registered: Apr-06
| Posted on Monday, April 17, 2006 - 10:15 am: |
how do i connect two amp to my HU when ive only got one pre-out? |
Gold Member Username: Carguy
Post Number: 5471 Registered: Nov-04
| Posted on Monday, April 17, 2006 - 10:48 am: |
Use RCA cable splitter. |
Bronze Member Username: Gkaste
Post Number: 11 Registered: Apr-06
| Posted on Monday, April 17, 2006 - 11:55 am: |
So one vote for seperate ground points, one vote for common ground points. Anyone else care to chime in? |
Bronze Member Username: Nanbakat
Mexico City Mexico
Post Number: 32 Registered: Mar-06
| Posted on Monday, April 17, 2006 - 01:18 pm: |
Use another distribution block to get both your ground points to come together to one wire. Then bolt that one wire directly to a suitable grounding point. If you have one ground point then it lessens the chances of having a "ground loop" that could introduce alternator whine into your speakers. This would sound like humming or a high-pitched whine coming through your speakers when you accelerate. |
