Home > Message Board > Car Audio > Head Units > Archive through May 04, 2006 > Do you lose power if you use a stock ...
Author Thread: Do you lose power if you use a stock cd player?
Username: Rollout4877
i have an 05 truck so i like my stock cd/mp3 player should i use the hi low adapter to connect my subs to it or will it not sound as good as if i used a aftermarket cd player?
Username: Theelfkeeper
Stockbridge, GA
Post Number: 1757
you just lose sound quality by using a LOC rather then getting an aftermarket HU.
Username: Illuminator
Post Number: 2875
And you lose a medley of sound adjustment options!
Home > Message Board > Car Audio > Head Units > Archive through May 04, 2006 > Do you lose power if you use a stock ... [ « Previous ] [ Next » ]
